Head Light Switch Removal (1969 Camaro) - Team Camaro Tech
Old Jul 28th, 05, 07:45 AM
Phillip_L Phillip_L is offline
Default Head Light Switch Removal (1969 Camaro)
Hello,
I know have seen this written before, but I can not find it. I am trying to remove the head light switch for the gauge panel. I can not get the knob off. I see a spring loaded button on the bottom of the switch, but I can not make it release. If I remember correctly, it does not screw off.
How do I remove the switch.
Thanks,
Phillip
Old Jul 28th, 05, 07:53 AM
TJS69 TJS69 is offline
Tom
Default Re: Head Light Switch Removal (1969 Camaro)
Press that button and you should be able to pull that shaft out. The knob stays on the shaft. and the shaft comes out !
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
gene_sc gene_sc is offline
geneo
Pull the knob out all the way and then push the button on the switch... you may have to wiggle the knob in/out a little to get it release
Old Jul 29th, 05, 05:15 AM
Thanks for all the help. I know I tried that the other day. Last night, I pushed the button and it came right out on the first try.
Thanks.
Phillip
Similar Threads
Brake light Switch Guido67SS Electrical & Wiring 6 Feb 24th, 04 03:00 PM
Head Light Switch Removal for a 68 Green Hornet Electrical & Wiring 6 Feb 18th, 03 08:14 AM
light switch removal 68 camaro jblake Electrical & Wiring 2 Sep 25th, 02 01:19 PM
Ignition switch removal on 67 camaro prostreet L-78 Tech 2000 6 Jun 16th, 01 06:10 AM
