Horsepower 67 Camaro - Team Camaro Tech
Old Aug 8th, 05, 06:27 PM
tonyvol tonyvol is offline
Default Horsepower 67 Camaro
Hey guys, Hopefully this isn't a stupid question. Does anyone know how much horsepower you can run in a 67 camaro without putting too much stress on the body or the frame. I don't want to install sub frame connectors. Is 425 h.p too much? What about 500 h.p?
Old Aug 8th, 05, 07:21 PM
pdq67 pdq67 is offline
Banned
Smile Re: Horsepower 67 Camaro
Sure, It show's up over time by making cracks at the rear window lower "V's" first.
And a powerful car can also "wrinkle" the area in front of each lower rear wheel well if I remember right, (read S/F/C's needed!), as well as crack the windshield!
Donno about hp required to do this damage to them tho, b/c my car was always pretty mild except for the time I had the full house, .060" over, 11.5 to 1 CR., with "trips" 409 "W" motor in it!
My car has the small cracks in it now!! AND I finally after all these years installed a pair of Jegs bolt-on S/F/C's!!
It amazed my how much easier it is to jack it up from the side now with them installed!!
pdq67
camarofreak camarofreak is offline
Tony Riva
Talking Re: Horsepower 67 Camaro
depends on a lot of issuse like gear ratio tire selection how hard you hammer on it etc.. but I had a 69 with 525 horse without frame conectors with 3:73 12 bolt and 295 50 15`s never had any problems!
Chevelle now!!! http://i15.photobucket.com/albums/a3...singleshot.jpg
Old Aug 8th, 05, 07:34 PM
Default Re: Horsepower 67 Camaro
I plan on running a 3.73 posi rear end and won't be drag racing it on the strip. I want to go the pro touring look, so I will probably run 17x8 on the rear and 17x7 on the front with street tires. I will most likely use the car for cruising, but don't want to tear the car apart if I get on it every once and awhile.
Old Aug 8th, 05, 09:03 PM
Farm Boy's Avatar
Farm Boy Farm Boy is offline
Steve
Posted by pdq67 - I had the full house, .060" over, 11.5 to 1 CR., with "trips" 409 "W" motor in it!
Wow! Did it take much to get it to fit? I think the W motors were the best looking engines to ever come down the line at Chevrolet. Do you have any pictures?
Steve
1967 Camaro
I drove it for the first time in 1972 when I was 15.
1956 Bel Air Sport Coupe
Better looking than a '56 Ford or Plymouth.
Old Aug 9th, 05, 07:30 PM
Banned
No Farm Boy,
The old 409 "W" motor dropped right in using all of my small block stuff including Z-bar! I had manifolds on it and even used two driver side Imp. 2.5" dia. exhaust pipes by cutting one and rewelding it 180 degrees and then bolting them on. I also had (2) long, 2.5" thrush glasspacks welded end to end under the cab and a little 2.0" x 12" g/p under the gas tank as a resonator down each side! Talk about CACKLE!!!
I did however get a '66 Buick Skylark H-D, A/C, 4-core rad. to cool it b/c my skinny, 350 rad. wasn't up to the task! But I had to strap and top bolt it in place b/c it didn't have stock side mounts like our cars rad's have.
421", (.060" overbore, 409") "W" motor, 11.5 to 1 CR forged pistons, I installed 2.19"/1.72" valves and ground h-ll outta the heads, NASCAR solid cam and a hogged out 348 trip cast-iron intake with (3) big 2GC Rochester 2-barrels on it off of 389 Pontiac 2-barrel motors...
Yes, I still loved the chrome "W" valve covers but after reworking the intake, the great big round chrome double snorkle intake wouldn't fit.
pdq67
Old Aug 11th, 05, 03:39 PM
shooterpcb shooterpcb is offline
cool! One of my Dad's friends has a 348 in a 54 Chevy lowrider 2 door with black paint and very little chrome on it. It's a great street rod. 3 dueces up top.
"There are two ways to do this... My way and the Wrong way." - Dale Earnhardt '99
Neil
http://www.chevymania.com/partsid
http://www.mortec.com
Old Aug 11th, 05, 07:37 PM
Eric68 Eric68 is offline
Eric
I think that about 350 HP is safe without SFC's. Yes you can run more but a 67 Camaro is 38 years old . . . and its unibody in back. It won't break right away with more HP, but you WILL do damage to the structure in the long run.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old Aug 12th, 05, 05:03 AM
DOUG G DOUG G is offline
RedЯuM
The amout of horsepower isn't an issue. Torque is whats going to do it, and I thing with enough traction a 6 could do it if driven like Warren Johnson. If it never hooks, it isn't a problem no matter how much hp/tq.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Aug 15th, 05, 06:48 PM
Does anyone have any pictures of SFC's that they either welded or bolted to their camaro? I was curious how they looked once they were installed.
Old Aug 16th, 05, 07:01 AM
67rsssvert 67rsssvert is offline
Robert
Tonyvol ... if ya use the search function on this site and type in ' sub frame connectors ' you'll find a ton of helpful info and pics.
'67 RS/SS Convertible
If anyone wants me for anything, I won't be anywhere. - Col. Henry Blake M*A*S*H 4077th
Old Aug 16th, 05, 07:05 AM
Eric
This isn't a picture of subframe connectors, but you can see them if you look close.
Old Aug 16th, 05, 07:10 AM
Robert
There's a good pic in this thread ...
http://www.camaros.net/forums/showthread.php?t=56831
Similar Threads
Holy Cow New CAMARO!!!!! BBC1 Bench Racing 39 Jan 10th, 06 07:15 AM
CAMARO IS BACK IN 2007!!!!!!!!!!!!!!!!!!!!!!!!! dawg Bench Racing 32 Apr 24th, 05 07:27 PM
Stainless steel body fastner kits for Camaro coporic Bench Racing 0 Feb 28th, 05 10:52 AM
The ultimate Camaro MarkM Performance 32 Jan 22nd, 01 03:52 PM
Missing horsepower Jim Karam Performance 26 Nov 10th, 00 05:11 PM
