| Team Camaro Tech Current Topic: Frame question: Small dent just behind the front tire. | ||
| Body Shop Paint & Body Forum |
I pulled off the right front fender (passenger side) today to work on the wiring, and I noticed a small dent in the frame. This dent is just behind the front tire, and seems to have only been dented, and not bent the whole frame. If the frame is a tiny bit bent (it doesn't look ,like it) can the front end still be aligned and be made to drive straight. The few times I was able to drive it (very slowly) I did not notice anything unusual in the front.
Now, here is what is bothering me. The front tire seems to be leaning in a little at the top (is that a good explanation). In other words, I think the toe, or is it caster, is off a little. Will an alignment fix this once I have the new front end kit installed and aligned? The ball joints are loose, but not terrible. When I had the rear end up, I really noticed this problem, but with it back on level ground, it is hardly noticeable, but now to me it seems like there is something wrong. You know how it is when you see a blemish, and the more you look at it, the worse it seems.
Craig ------------------------------------------------------------------------------ Now you will see that evil will triumph, because good is dumb. -Dark Helmet 1967 Camaro 1965 Mustang 2007 Mustang |
| Sponsored Links | ||
Advertisement | ||
A dent behind the wheel is the signs of a front end colllision..... if the tire is layed in at the top you may have camber issue... any shimes on the upper control arm?? How does the frame horn look? ( front of frame by bumper mounting)
Yep, classic bend, very common in that area. The frame horn goes out to the right and back, that is the "weak" point so it gives.
1965 Buick Gran Sport Convertible 1948 Chevy pickup. 2003 Dodge Caravan 1959 Rambler American (Yeah I said RAMBLER, you want to make something of it punk?) "Fan of most anything that moves human beings" |
There are some shims on one side of the a-arm. The frame appears to be ok in the front, at least as best as I can tell. If there was a collision, am I screwed, or can it be adjusted. The inside of the frame does not look like it has moved, only the outside, like it is a little bit collapsed. The dent is very minor, and the onyl way I was able to tell that it wasn't supposed to be there was to look at the other side.
If it is bent hehind the wheel, the crossmember can be off ect... If the front of the frame looks sweet then car may have had a wheel shot..... A body shop or a frame and axle shop should be able to fix it if not too bad... take along a frame diagraim, so you have measerments and they shouldn't whine too much
| Sponsored Links | |
Advertisement | |
Similar Threads
| Question about engine frame mounts | Sunan | Engine | 2 | Apr 14th, 05 02:16 PM |
| Front end kit in Canada | Mark Yetman | Brakes, Suspension & Steering | 19 | Mar 14th, 04 01:27 PM |
| Trunk Lid Fit Problem | RPOL72 | Body Shop | 8 | Aug 27th, 03 01:45 AM |
| sizes from Chevy High Performance article | michaelm5 | Wheels & Tires | 10 | Jan 16th, 03 02:53 PM |
| finally new wheels and tires | michaelm5 | Wheels & Tires | 14 | Jul 12th, 02 01:09 PM |
