Transmission Not shifting - Team Camaro Tech
Old Aug 15th, 05, 07:07 PM
88IROCZ28 88IROCZ28 is offline
Question Transmission Not shifting
Just bought a 88 z28 with a 305tpi,the transmission will go into reverse,first and shift to second with no problem but it will not go into third gear. What suggestions do you guys have
Old Aug 21st, 05, 06:19 PM
William van Hulst William van Hulst is offline
Tech Team
Default Re: Transmission Not shifting
Is this a stock setup? Was it working yesterday or did you just change the motor? Reason I ask is quite simple. I just swapped a regular 350 (carb)with some minor mods into an 86. Never paid any attention to TV cable as the last time I worked on any Chevies it was a 68 truck with a 327 and I installed a th350 with the regular kickdown. (also disk front end and newer rear in back too) So here I am going around the yard with this thing (Z) in first and it wont go to second. Had to start reading. Of course your problem seems different but if you have some extra information as to what you may have been working on, it would really help?
I mean if nothing was worked on, it would seem the trans just has some problems that need a transmission shop? I read, bought the adaptors and next step is lockup? Any idea what the last guy might have done?
Old Aug 21st, 05, 07:45 PM
Musclerodz Musclerodz is offline
Sounds like the 3-4 clutches are toast in the tranny. Is it a high mileage car. We just replaced the 3-4 clutches in my 4L60E that were on the verge of not working while replcing the rear main seal and resealing the tranny.
Mike
Old Aug 22nd, 05, 09:08 PM
Yes it does have high miles 100,000 plus,no mods have been done to the engine, I bought the car with a hole inthe freeze plug got it fix and drove it around for a few miles and it tries to shift into third but won't, how much of a job is it to change those clutches? Thanks for the info
Old Aug 23rd, 05, 01:57 PM
Don't know I let my buddy work on my drivers. However I will be helping him build a 700R4 for me shortly for one of my projects.
Mike
Old Aug 23rd, 05, 06:05 PM
dnult dnult is offline
Originally Posted by 88IROCZ28
...how much of a job is it to change those clutches? Thanks for the info
Yer talkin a rebuild. All the guts come out, get cleaned up, and all the rubber, clutches and worn parts replaced.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Aug 24th, 05, 03:57 AM
Everett#2390's Avatar
<Jake 68's Rule
Go to your local Trans parts tore and buy an ATG manual for the specific model of trans. Inside, it will show you where to hook-up a pressure gauge, 0-200 PSI, to see if oil is being delivered to the each clutch pack for the gear selected.
If there is pressure applied and it is steady, then as dnult suggested, disassembly is in the future.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Aug 24th, 05, 03:52 PM
BAILBATOORA BAILBATOORA is offline
Once I Had The Same Problem And I Was Struck In The Desert When I Opened The Hood And Saw Inside I Found Out A Wire Attached To The Batery Was Burnt And Cut Loose, When I Managed To Fix It And Attaced It Back With The Battery The Car Became Ok And Tell U What I Donot Any Thing About The Cars Later A Mechanic Told Me That This Was The Transmussion Wire And Transmission Works With The Battery Any How I Doonot Not Wether He Was Ok Or Not But Since Then My Car Is Working Fine It Is 94 V-6 3.4 Automatic. If U Find My Reply Funny Plz. Forget Me
Similar Threads
Transmission shifting late dustys Troubleshooting 8 Sep 6th, 09 04:54 PM
Transmission shifting very sloppy garfield Transmission & Driveline 1 Mar 16th, 05 11:16 PM
TH350 Transmission Shifting blue68ss Engine 12 Jul 30th, 02 01:04 PM
transmission not shifting soon enough teejdio Troubleshooting 1 May 24th, 02 11:22 AM
Transmission Shifting locz Troubleshooting 3 Dec 4th, 01 05:55 PM
