10 Bolt Adventure - Team Camaro Tech
Old Aug 16th, 05, 07:49 AM
freebird freebird is offline
Default 10 Bolt Adventure
HI All, Time for a new Rearend....the old 10 bolt finally gave out on me. Had a few questions.
Going to start searching for a 8.5 Inch 10 bolt as money for a 12 bolt is not in the budget.
1)I realize they will drop right in if I find one from a 1972 or Later Nova...However are there any other cars/years these came in??
2)Where are some good places to start looking? Never been on a Rearend hunt before (That sounds kinda funny)
3)Just in case I come across a 12bolt, what years and types of cars will be a bolt in for the 1968 Camaro...
Thanks!!
Old Aug 16th, 05, 12:39 PM
Default Re: 10 Bolt Adventure
HI All Used the old Search button and found some good info....had one last question...When I hit the junk yards is there any way to tell if a 8.5 has posi from looking at it, moving the wheels..etc. Or is the only way to tell by opening it up??
Old Aug 16th, 05, 01:54 PM
JimM JimM is offline
Jim
depending on if the driveshaft is on or not... if you turn one wheel and the other turns in the same direction, itsa posi... not foolproof, possible for a posi to turn the opposite way if the driveshaft is on and locked, or if the clutches are shot.
on an open rear, the opposite wheel will always turn the wrong way.
All GM posi's had a tag, I think attached to the fill hole plug, suggesting the use of posi additive.
Last but least, there will be a 2 letter code on the front of the pass axle tube. If you have a really big book with, it'll tell you, or you post it here, and come back the next day if it'sa yes.
Old Aug 16th, 05, 02:13 PM
Farm Boy's Avatar
Farm Boy Farm Boy is offline
Steve
The chances of finding a 72-79 8.5” Nova or Nova clone (Apollo, Omega, Ventura, Skylark) rear end with posi are pretty slim. Don’t pass up a clean housing because it doesn’t have posi.
Steve
1967 Camaro
I drove it for the first time in 1972 when I was 15.
1956 Bel Air Sport Coupe
Better looking than a '56 Ford or Plymouth.
Old Aug 16th, 05, 05:12 PM
400bird 400bird is offline
wait, 72-79 nova?
I thought it was 68-72 novas that had the rear end that would bolt right up to a 67 or 68
Old Aug 16th, 05, 06:03 PM
Eric Kammerer Eric Kammerer is offline
68 to 72 Nova would have the same rears (8.2 10-bolt and 12-bolt) as the 67-69 Camaros. The 8.5 came into use in late 72.
So, late 72 to 79 is correct, but you have to watch from 75 or 76 on, because they started using the weak 7.5 10-bolt too. Visually the 8.5 and 7.5 are different, so it's easy to avoid the 7.5.
http://www.novaresource.org/axle.htm
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Aug 16th, 05, 06:55 PM
Brad74 Brad74 is offline
That nova resource site is great. It is what I used to find my rear end (that did not sound right!). Any way mine is out of a 74 and bolted up with no problem. Got a carrier out of a mid 70's trans am and 3.42 gears ready to roll.
68 Camaro, 8.5" Nova rear, 3.42 gear, Hotchkis 2" rear spring drop, Autometer 5 inch gauges, 92 Z-28 wheels, TH700R4, Fast Burn 385
Similar Threads
Alternator Bolt Troubles redlines4us Engine 7 Sep 14th, 05 08:36 PM
1968 door alignment Steve W Body Shop 5 Sep 9th, 03 04:15 PM
Trunk Lid Fit Problem RPOL72 Body Shop 8 Aug 27th, 03 01:45 AM
Adjustment to fender? Winch Body Shop 4 Mar 10th, 02 01:46 PM
BIg Block Info I got off the web! Very long! pdq67 Performance 6 Jan 5th, 02 02:08 PM
