Which Piston Ring Goes Where? - Team Camaro Tech
Old Aug 20th, 05, 12:02 PM
Cameron Cameron is offline
Default Which Piston Ring Goes Where?
I am assembling my 400sb and I am using Hastings moly rings for it. The instructions aren't very clear at all as to which compression ring goes in what groove. I have two rings, one has a bevel and a dot. I know the dot goes up, and I think that ring goes in the top groove, but I'm not for sure. The other ring has no bevels or markings of any kind. I looked at Hasting's web site, but I found nothing that helped. Do any of you guys know what ring goes where?
49 Chevy 3100 Project
Acro Sport II Biplane
69 Camaro
400 Small Block
AutoGear M22 4 Speed
Old Aug 20th, 05, 12:32 PM
zdld17 zdld17 is offline
Don
Default Re: Which Piston Ring Goes Where?
If you know that bevel and dot are top ring,, then no markings rings is # 2 gland. There should be some type of interal beval on that second . Both are compression and should be cast iron .
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Aug 21st, 05, 02:14 AM
CNC BLOCKS N/E CNC BLOCKS N/E is offline
Banned
I believe that the ring with no markings goes on the top and the ring with the dot up and the bevel on the inside of the ring should be on the bottom is your second ring and is important to get the second ring where it belongs as its a tapered ring and is also called a scaper ring. Hope this is of some help to you.
Old Aug 21st, 05, 02:42 AM
BlackoutSteve BlackoutSteve is offline
Steve
Ask them!
http://www.hastingsmfg.com/
Nov 68 Van Nuys. 327 floor-shift-auto, Frost Green and not much else when new.
http://img233.imageshack.us/img233/3...sychedelic.jpg
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
Old Aug 21st, 05, 06:27 AM
BillK BillK is offline
Cam,
Are the rings still in the box ? Did you open the box correctly from the "zip lock" side ? If so the little end "flaps" tell you where each ring goes. If you already have them out of the box and they are the usual Hastings Moly rings.... the one with no bevel or markings and the shiny face goes on top and can go either way. The one with the bevel should have a dot on it too. This is the second ring and the dot goes towards the top of the piston. If you are not certain, wait until Monday and call Dawn at Hastings with the ring set part number and she will tell you for sure.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
Enginerepairshop.com
Old Aug 21st, 05, 07:14 AM
Racing 68 Racing 68 is offline
Joe
On the hastings rings the ring with the dot up, bevel down is the second ring, the ring with no markings or bevel is the top ring. Also the top ring is the one with the shiny face,the moly coating, the second ring will be a dull cast look just like the sides. I have installed about 200 sets of these rings over the years and i am very familiar with the placement of the rings
Old Aug 21st, 05, 01:09 PM
I never looked at the box, I took them all out before I did anyway that wouldn't have helped. I just assumed that the instructions would show me. I'm glad I asked because I thought that the beveled ring with the dot went in the top groove. I think that I will call Hastings tomorrow just to ease my mind though.
69 Camaro
400 Small Block
Similar Threads
Piston Ring Gaps - How Accurate? Neil B Engine 8 Apr 21st, 05 06:14 AM
Piston ring placement Z10Joey Engine 2 Feb 1st, 04 07:25 AM
Piston ring order Kevin68 Engine 2 Jul 17th, 03 01:44 AM
Recommended Piston ring gap camsdad Performance 5 May 14th, 02 12:58 PM
Piston Ring Install Fiasco - HELP!!! JonT Engine 7 Nov 29th, 00 07:06 AM
