| Team Camaro Tech Current Topic: Any Ideas | ||
Well to start things off I finally got my car finished. There is'nt a speed shop around here with a dyno and i can't really get a ball park estimate of horsepower. heres my combo,
1985 Z-28 305 tpi motor cloyes double roller timing chain comp cams 276hr-14 220 intake 230 exhaust world products s/r torquer cylinder heads 58cc 1.940 intake 1.500 exhaust crane energizer roller rockers 1.6 ratio bbk adjustable fuel pressure regulator set to 58 gph holley air foil removed the screens on the mass air removed air box. fabbed new one to come through fog light holes 58,000 volt flamethrower ignition module along with cap accel 8.8 race wires ngk plugs flowtech headers with y pipe three inch exhaust no cat to flowmaster 80 series stock 700r4 with corvette servos and trans go shift kit 3.73 rearend granetelli fuel pump 255 lph hows it sound? any horsepower ideas? Last edited by asmodeus419; Aug 22nd, 05 at 12:29 PM. |
| Sponsored Links | ||
Advertisement | ||
Should make close to 300hp, sorry not to familiar with how much a 305 tpi motor makes tq wise, but I know 350s make around 450tq, so a 305 should make around 400+tq. I have a 305tpi 91, thats ran 14.1 @ 98, which is around 260-270hp range. Its stock from intake to pan, but has edy headers, exhaust, crank puley, msd, k&n. You should be makin more then me, and you should run 13s.
67 camaro 373s: 420 - 641hp HRcam 1.40, 9.90 @ 135 502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7 62 Nova 383/200-4R/12-bolt w 373s 224/224 HR cam 1.57 10.97 @ 121.2 |
I would seriously recommend a 2500-2800 rpm stall lockup convertor. Thats quite a bit of cam for a stock converted 700r4 and a 305. Should run very strong up to 6000 rpm if the intake can keep up with it.
| Sponsored Links | |
Advertisement | |
Similar Threads
| Fuel pressure keeps dropping, any ideas ? | jaytone | Camaro Tech | 9 | Jun 4th, 05 09:02 PM |
| Ideas on alignment of 69RS front parts? | click | Body Shop | 5 | May 31st, 05 06:47 PM |
| Long term storage ideas (locations) | JHunter | Bench Racing | 8 | Apr 6th, 05 09:18 PM |
| Throttle Linkage ideas | 69CamaroRacer | Engine | 11 | Jul 25th, 04 11:31 AM |
| pulley ideas needed - 1968 302 MO | SooperDave | Engine | 1 | May 28th, 04 04:33 AM |
