wiring for Sun Super Tach II-- what wire goes where? - Team Camaro Tech
Thread Tools Display Modes
Old Sep 1st, 05, 03:33 PM
tmannet tmannet is offline
Terry
Default wiring for Sun Super Tach II-- what wire goes where?
I just purchased a used Sun Super Tach II, it has 4 leads coming out of it. It's been 25 years since I've installed a tach, can anyone tell me what wire goes where? One lead is red (hot wire to fuse box, correct?), one is black (ground, correct?), one lead is green, one is blue.
Thanks for the help-Terry M.
Old Sep 1st, 05, 03:55 PM
sdtsdt sdtsdt is offline
Default Re: wiring for Sun Super Tach II-- what wire goes where?
Green to neg coil terminal ... Black to ground... Red to switched 12 volts ... Blue for illumination ... tap off dash or accessories lighting
Old Sep 1st, 05, 04:20 PM
Terry
Thanks so much, I'd like to get this tach installed this afternoon. What's the best place on the fuse box to wire in the hot wire-- 10A, 15A, 20A?
Terry M.
Old Sep 1st, 05, 07:08 PM
When tapping off a fuse socket, remember that the socket has a "always" hot side "upstream" to the fuse. The opposite, downstream side is only hot when the fuse is good. If you tap on the always hot side, it doesn't matter what rating the fuse is since you won't be drawing power thru the fuse . If you get on the downstream side of the fuse, I would go with a higher amp choice. But remember, the connection ought to switched ... To be clear, when I say upstream, I mean the side of fuse that will always have power. Downstream is the side of the fuse connector that has power only when the fuse is intact. Upstream, downstream, the socket should only have power when the key is on.
Old Sep 1st, 05, 07:22 PM
Terry
yes I got it, thanks. Hard to believe I used to work for an electrician, years ago, I can't remember much...
Terry
Old Sep 9th, 05, 03:51 PM
Terry
Default Re: wiring for Sun Super Tach II-- where should I attach the blue wire?
I have the tach hooked up and working, the only thing left is the blue wire for illumination...I can't find a convenient place to splice it in, I don't want to cut my wiring any more than I have to. Where should I attach it? (this is a '68 Camaro).
Terry M.
Old Sep 9th, 05, 07:31 PM
dnult dnult is offline
What model year is it? Does it have glass AGC fuses? There may be a tap for instrument lamps on the fuse block. Could also buy a little metal tab that plugs in around the fuse that you can hook a wire to. If you're looking for a place to splice into, consider the ashtray lamp circuit.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Sep 10th, 05, 11:16 AM
Terry
It's a '68 Camaro, I'll have a look & see if there's a place to connect power for instrument lamps on the fuse box, or possibly ash tray lamp wire--
Thanks Terry M
Old Apr 15th, 15, 09:17 AM
goos805 goos805 is offline
I have a 91 Lincoln Towncar that has two corle packsI need to know where the green wire gose to . From the Sun Super Tach II can you please help me thank you
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: wiring for Sun Super Tach II-- what wire goes where?
Location
Location
First Name
Human Verification
Similar Threads
Tach Wooooosss luccamaro68 Performance 7 Apr 26th, 05 07:14 PM
67 tach wiring with HEI ??? ANYBODY RandyB.. Tech 2003 2 Jun 10th, 03 08:13 PM
Tach Wiring question MangeMD Electrical & Wiring 2 Apr 24th, 03 11:03 AM
msd wiring Jbboa Tech 2000 5 Aug 13th, 00 05:14 PM
HEI Wiring for the 12V, Gnd, and Tach ? Shawn Tech 2000 6 Mar 18th, 00 08:44 PM
