Third Generation 1982-1992
Old Sep 6th, 05, 05:40 PM
richard mains richard mains is offline
Default 84 camaro Z28 HO , 90K miles ,brake light problem
brake light comes on intermittently while driving and will USUALLY go off if I shake the emergency brake handle while in the down position .. brake light flickers on and off if I shake the emergency brake handle while car is or is not moving. Brake light will go OFF if I pull UP on the emergency brake handle (seems odd).
I think there must be a short in the emergency brake light switch?? BUT where is it located and how do you get to it?
Brake fluids are ok, pads ok, no sign of brake fluid around wheels (no leaks in cylinders) and brake pedal holds when pressure applied.
Old Sep 7th, 05, 08:46 PM
blazincamaro blazincamaro is offline
Default Re: 84 camaro Z28 HO , 90K miles ,brake light problem
man i doubt youll get any type of answre, from what i seen these forums pretty much suck for third and fourth generation camaros im gonna go find some different forums
Old Sep 8th, 05, 07:58 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is online now
Team Member
Scott
I remember that there is a switch at the base of the e-brake handles on that car, near the handle pivot. You will have to pull the console apart and take a look. The switch may be loose or bad.
Mr. BlazinC, I don’t think that is totally true. But you need to realize this is really a site for 1st gen cars. That is where the knowledge base here is centered. For problems like engine, trans, etc., you often get answers because engines are engines, and so forth. But when you get to the model specific details, well, that may be out of the range of experience. Most people don’t respond to questions they can’t answer. No info is better than bad info, right? The problem with other sites, as I see it, is info for the sake of info, right or wrong. Especially as the apparent average age of its users drops (usually easy to spot by poor spelling & grammar).
Snippy answers don’t help you, either, Mr. BlazinC. Your response was less than useful, as well. I find the users here very willing to help when they can, no matter the gen.
Camaro References
http://www.camaros.net/ (1st Gen Camaros)
http://www.nastyz28.com/ (2nd Gen Camaros)
http://www.thirdgen.org/ (3rd Gen Camaros)
Good luck Rich
Similar Threads
Fog/Driving light removal on 95 Camaro Dave Chang Tech 2001 4 Dec 14th, 01 08:19 PM
69 Camaro trunklid fit problem japper Body Shop 6 Jul 25th, 01 05:06 AM
89 CAMARO CHECK ENGINE LIGHT lgmoore Troubleshooting 1 Feb 15th, 00 08:20 PM
fuel problem HELP jokerdwarf Troubleshooting 2 Dec 11th, 99 04:17 PM
fuel problem HELP jokerdwarf Tech 2000 3 Dec 7th, 99 07:41 AM
