10 Bolt Rearend - Team Camaro Tech
Old Oct 12th, 05, 12:09 PM
chip_127 chip_127 is offline
Charles
Default 10 Bolt Rearend
I am in the process of restoring a 68 and I noticed that the big ring gear in my 10 bolt has a few teeth that are chipped. My question is, should I put the money into rebuilding this rearend, or find an aftermarket one to replace it?
Old Oct 12th, 05, 12:14 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Default Re: 10 Bolt Rearend
How deep are your pockets?
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Oct 12th, 05, 02:05 PM
Charles
Not very deep!
Old Oct 12th, 05, 03:37 PM
HwyStarJoe's Avatar
Chip,
Are you just planning on normal cruising, back and forth to work and out for joy rides? Or do you plan to race it a few times a year and improve the handling for spirited road performance? A bigger, more powerful engine?
The original 8.2" 10-bolt will be a lot less expensive to rebuild than to replace, obviously. A new set of gears and a rebuild kit with bearing/seals will run you a $300, plus the cost of having them installed. Add $540 if you want to swap the carrier to a posi unit. Look at spending $500 or $600 to fix that rear end. $1200 to make it posi.
These are just guess-timates. Prices may vary in your area.
A 'new' rearend, when all said and done, will gouge your wallet for $2000. A used rear end might cost you $100 or $1000, but it's used.
The original rearend is just that... original to the car. If you want to keep it original that is.
You can have the gears and bearings replaced locally. If you're on a budget, that's what I'd recommend.
SEMA ACTION NETWORK
Old Oct 12th, 05, 05:21 PM
big gear head big gear head is offline
Freddie
If you want to rebuild a rear end I recommend finding an 8.5 10 bolt from a '71 or later Nova, or one of the GM Nova clones. This is a stronger rear end and it will cost less to build it because the parts are cheaper. You will probably need a set of multi leaf springs because not many of the 8.5 rear ends had mono leaf springs. If you want to make it look like the standard 8.2 10 bolt you can swap the cover. The 8.2 cover will fit the 8.5 rear end.
'69 RS/SS396 pro street/427/4spd/9"
http://www.camaros.net/showroom/show...00&ppuser=1922
Old Oct 12th, 05, 05:30 PM
rojo rojo is offline
Robert
Freddie,
Has the Eaton 8.2 posi gone up that much? Like Joe mentions they are $540 from Summit. It's been awhile but I bought one from you for $349.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
'77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25
TC member #18
Old Oct 12th, 05, 05:33 PM
67SS&99SS 67SS&99SS is offline
Andy
I just rebuilt my 8.2, and I had about $900.00 in the rebuild. I put an eaton posi in it, all new bearings and seals, and motive 3.73 gears. I am happy with it, everything is tight and fresh. You could put a solid pinion spacer in it to make it a little stronger if you want. I don't run my car w.o.t. from a dead stop, I'll wait til I'm running about 25 or so then nail it, so I don't worry about grenading it. I'm sure it wouldn't hurt the rear running street radials but thats my philosophy. Plus when you drop all of that money in it, it makes you think twice about abusing it.
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
My Cars
Old Oct 12th, 05, 05:35 PM
Andy
rojo: I just got my Eaton posi back in June from Rick's Camaro and gave right at $400 for it. I think they've gone up to $430 now.
My Cars
Old Oct 12th, 05, 05:59 PM
Freddie
The 8.5 Eaton is $410, and I think the 8.2 is about the same. All Eaton prices went up early this year.
Old Oct 13th, 05, 05:02 AM
DOUG G DOUG G is online now
RedЯuM
I agree with Freddie, unless your going to be at the track a lot or drive it hard by power shifting and the like, lots of burnouts, the 8.2 will live.
I bought all my stuff (for the 8.2) from Freddie not all that long ago and haven't looked back.
Eric68 was running one for quite a while (1.5 60's, and low 11's high 10's) but moved on to an 8.5.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Oct 13th, 05, 07:05 AM
Charles
I do not plan on racing. I am building it more for a street "driver". I am looking at putting a 350hp crate motor in it, with a 5 speed tranny.
Old Oct 14th, 05, 03:19 PM
mike p mike p is offline
National Drivetrain in Chicago (800) 507-4327. Purchased in Sept:
Motive Gears 8.2" 10 bolt 3.08 28 spline ring/pinion $250
Differential install kit $61.45
Eaton posi 8.2" 10 bolt 3.08 $375
"Street driver" in progress....
1968 327 sport coupe. Son of original owner.
Similar Threads
12 bolt swap in 1967 Camaro jrt67ss350 Brakes, Suspension & Steering 5 May 3rd, 07 07:38 PM
Tips on converting to 12 bolt jethro Brakes, Suspension & Steering 9 Jun 12th, 04 06:34 PM
Adjustment to fender? Winch Body Shop 4 Mar 10th, 02 01:46 PM
Never ending spacing problem tl757 Body Shop 6 Jan 26th, 02 08:56 AM
Opinions...Build me your 9 inch or 12 bolt rearend Procharged69 Tech 2000 2 Mar 1st, 01 09:56 PM
