Fourth Generation 1993-2002
Old Oct 23rd, 05, 03:13 PM
2002camaroocala 2002camaroocala is offline
Default 2002 Camaro 30,000 miles Fuel Pump Whining
I have a mint 2002 camaro v6 and I notice that the fuel pump starts to whine when I am sitting stop in traffic. The noise is coming from the rear passenger side. i think its the fuel pump becasue while sitting idle in brutal traffic the whining noise got lower when the idle dropped abit on its own. The longer you sit the louder it starts to get. While annoying you cant hear it withthe radio on Is it going to leave me stranded. The car hardly has any miles on it. Whats the deal. Help
Old Oct 24th, 05, 08:25 PM
Default Re: 2002 Camaro 30,000 miles Fuel Pump Whining
So either no one has ever had a whine in the rear of a 4th generation camaro or no one really works on camaros anymore. I thought this group would be informative. I hope the mechanics out there are more useful then this group or its time to trade into a ford mustang. When I had my ford I got a response from their board in a few minutes. And I had it from new with virtually no problems till about 80,000 miles. If Camaros start breaking down at 30,000 plus then they are built like ****. One thing I love about my car is how it holds the road more stable then my ford but if I have to worry about breakdowns then its not worth it. Maybe thats why they scrapped them.
Old Oct 25th, 05, 05:43 AM
OverAnxious OverAnxious is offline
Great way to get people to help you on a forum...
Is your fuel pump inside the tank on a 4th gen? It is not uncommon to hear the in tank whine on the 99-02 pickups, maybe it is the same on your car.
Joe
Over Anxious 67 Camaro RS/SS L78 / 5th Gen Blog / Modern Camaro (5thgen.org) Forums
Michigan Classics - Classic and Muscle Car Enthusiast Resources
Hot Rod Search - Google for Gearheads
Old Oct 25th, 05, 12:45 PM
400bird 400bird is offline
ya a lot of gm pumps make noise, and on some it is normal but on others it is a sign of a dying pump
you could run a pressure test and see how well the pump is keeping up with demand
but most of the reason you didnt get a response is because most of this site is about 1st gen camaros
Old Oct 25th, 05, 01:39 PM
ZZ430DropTop67RS's Avatar
ZZ430DropTop67RS ZZ430DropTop67RS is offline
Don
2002camaroocala, I just saw your first post, I work on a lot of 4th gens.
I must say your follow-up didn't exactly make me want to gush forth with an answer.
Don ~ TC Member #15 Gold
Old Oct 25th, 05, 02:28 PM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Attacking folks is no way to get help... We try to help where possible but don't want to feed you answers you can't use. I just realized you only waited 5 hrs through our slowest time of the day and came back attacking folks. Good luck you'll need it with your approach?
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Oct 25th, 05, 04:11 PM
zdld17 zdld17 is online now
Team Member
Don
Don't know how mechanically inclined you are but I would try to check the fuel bypass valve or solenoid , what ever controls pressure . Check to see if you are sending unused fuel back to tank. My guess is 1) it pressuring up and causing the pump to overload. 2) getting ready to check out . My son has a ws6 and he has about 80k on it and it whines a little but he listens to rock. 3) its a female and need to take it shopping.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Oct 25th, 05, 06:15 PM
dnult dnult is offline
My 94 pherd F150 used to buzz like crazy. Have you ever run the tank dry or frequently run it low? The pump lubricates and cools itself with the fuel. If figure low / empty fuel is a prime contributor to problems. I agree that a pressure test is a good thing to do. See if autozone will loan you one. If the pressure is good, you may want to listen to rock as zdld17 suggested or buy a new pump.
Hear is another thought, make sure the mounting for the pump is in place and flexible. Perhaps fuel has stiffened the rubber and made it transfer vibration more.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Similar Threads
Fuel pump issues Fattony Troubleshooting 8 Oct 18th, 05 08:16 PM
Second gen fuel pump on first gen CurtiSS 69 Engine 1 Mar 1st, 05 07:02 AM
Fuel pump is dead, EFI pumps reliable/good? 67RS502 Performance 3 Jan 20th, 05 03:59 AM
Fuel Pump? 83CamaroProject Camaro Tech 4 Apr 28th, 04 01:46 AM
fuel pump question? hi-po327 Tech 2000 2 Jan 6th, 01 05:47 PM
