Best Gear Oil to use in a Muncie M20 - Team Camaro Tech
Old Oct 29th, 05, 12:27 AM
JEFFMB JEFFMB is offline
Jeff
Default Best Gear Oil to use in a Muncie M20
Hi folks, getting ready to put in my 4 speed, it's been awhile since I've bought gear lube, whats the hot ticket nowdays for the old Muncie M20..
Thanks,
Jeff
Old Oct 29th, 05, 04:15 PM
12run 12run is offline
Default Re: Best Gear Oil to use in a Muncie M20
Good old 85W90 was always good enough for me.
69 RS 355 Tremec 5-Speed 4.11's
Old Oct 29th, 05, 05:57 PM
pdq67 pdq67 is offline
Banned
Thumbs up Re: Best Gear Oil to use in a Muncie M20
Ditto!
Dark teal colored stuff should smell a lot like good old EOS!!!
pdq67
Old Oct 29th, 05, 06:37 PM
cortezsilver cortezsilver is offline
Billy Moss
If you want to go synthetic use redline 75/90NS
Old Oct 29th, 05, 07:28 PM
vince69 vince69 is offline
vince
royal purple, worth its weight in gold.
1969 camaro 383ci\m22\411
pic is in my profile
Old Oct 29th, 05, 08:06 PM
JodysTransmissions JodysTransmissions is offline
Originally Posted by pdq67
Ditto!
pdq67
I also agree about the standard 85W90 lube.
As much as I like the newer fluids as stated, they will usually push out the front bearing retainer. After that, it will wind up getting on your clutch. Slip sliding away.
Some of the (an option) Autogear main drive gear/front bearing retainers use a lip seal. This will keep those light weight fluids from pushing out the front.
Regards, Jody
Jody Haag
JodysTransmissions@verizon.net
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-682-1602
Auto Gear Muncie Distributor & Builder
My '70 Chevelle: ZZ502/502 ROD 6 Speed
Old Oct 29th, 05, 08:30 PM
ZZ430DropTop67RS's Avatar
ZZ430DropTop67RS ZZ430DropTop67RS is offline
Don
Ditto.
Don ~ TC Member #15 ~ http://www.flickr.com/photos/46701464@N06/
Old Jul 7th, 06, 12:17 AM
MaxR MaxR is offline
Tech Team
I have a 5 gallon bucket of Royal Purple Max Gear 90. Will that work?
Old Jul 7th, 06, 07:01 AM
Dave69Z Dave69Z is offline
I use valvoline 80-90w gl-5 with mt-1 spec per transmission manufacturers recomendation. It is a new autogear m-22w. Seems to work great in all temperatures.
Old Jul 7th, 06, 01:43 PM
Straight-line-69 Straight-line-69 is offline
Agree,..the chief engineer (George) at Autogear says NOT to use synthetics in his Muncies,..the synchros don't work as well. He recommends Valvoline 80-90 conventional gear lube with the MT-1 sub-spec (mentioned above) which is good for the yellow parts. Other lubes such as Castrol, don't have this sub-spec.
And it's no secret syns will leak before mineral lubes as mentioned above.
Old Aug 30th, 07, 10:32 PM
RamJam RamJam is offline
Question Re: Best Gear Oil to use in a Muncie M20
I know this post is old but still hoping for help. I have a Muncie M-21. I want to make sure I put the right gear oil in it. I checked at advance Auto they have Valvoline 80-90 heavy duty for $4.88 a qt. Is this what I need? If not tell me what and where to get it and price. Wal-Mart has Rotella is that any good?
I already have a bad 2nd gear sync (It pops out sometimes). Mainly when I get off the gas. I don't want it to get any worse infact I'm hoping that changing the oil will make it a little better. Also how much do they hold? I've heard 1.5 and 2.5qts which is it?
(My pages)http://www.cardomain.com/memberpage/214503
1967 Camaro coupe Deluxe interior LT-1 350 w/ 4spd. M-21 trans and 12 bolt rear.
67 Camaro
Old Aug 31st, 07, 04:27 AM
77thor's Avatar
77thor 77thor is offline
Fred
I prefer Valvoline, but it's just a personal preference....
Just be sure to get a brand name oil.
Anyone know what the fluid capacity of an M20 is??
How many quarts??
1969 Camaro SS 350, M21, 12 Bolt Posi
Old Aug 31st, 07, 08:57 AM
68zproject 68zproject is offline
Harvard
I don't remember exactly but I think it's close to 40 ozs. And MacNeish said to never use synthetic.
1968 Z28 British Green, all original except CE 302 engine. Have original owners booklet and protect-o-plate.
Old Aug 31st, 07, 05:55 PM
bilydean bilydean is offline
check this out at the Chevelle site. It talks about which oil to use and why.
http://www.chevelles.com/forums/showthread.php?t=132305
Dean
Old Aug 31st, 07, 05:58 PM
67sprtcp 67sprtcp is offline
I put valvoline in mine and it shifts flawless.
Similar Threads
Muncie Drive Gear Help! tim68rsss Transmission & Driveline 5 Mar 10th, 05 02:15 PM
Speedo gear change on a muncie DRJDVM Transmission & Driveline 3 Feb 8th, 04 09:28 AM
Muncie hung in gear Cameron Engine 6 Apr 19th, 01 12:11 PM
