Short near glove bock causing int lights to stay on - Team Camaro Tech
Old Nov 4th, 05, 06:03 AM
Greg O Greg O is offline
Default Short near glove bock causing int lights to stay on
I have an electrical gremlin in my 69 Camaro. First let me point out that my electrical skills are limited so any help would be appreciated.
This year I started having an issue where the interior lights would come on for no reason at times. I pulled the switch in the driver's door thinking that may be it but the lights stayed on even when I pulled the switch. Then when I slamed the door getting out of the car, the lights went out!
After the lights comming on and off several times over several days, I tracked the issue to near the glove box. I had a heavy coat in the passenger floorboard. When I hit the brakes after a drag run the coat slid forward and pushed underneath there and the lights came on. When I pulled the jacket out the lights went off. If they came on again, I could tap on the glove box (underneath) and the lights would go off.
Messing with the switch in the glove box didn't do anything. I guess I will pull the glove box and see what's back there but does anyone have any ideas what I should look for?
Thanks!
69 Camaro, 3450lbs., 406, Cal Tracs, Coan 10", 3.73 gear
D1SC blow thru, pump gas, 9.3:1, ~8 PSI,
1.319 60', 6.005 @ 115.4
Old Nov 4th, 05, 03:24 PM
69-er's Avatar
69-er 69-er is offline
Larry
Default Re: Short near glove bock causing int lights to stay on
There is a single white wire running from the driver's door switch across the dash over to the passenger door switch. If this wire is grounded anywhere along its length it will complete the circuit and turn all courtesy lights on. I think you are on the right track. There might be a bare spot in the wire behind the glove compartment.
Larry
Old Nov 4th, 05, 10:13 PM
Chevy-SS Chevy-SS is offline
Dave
Yeah, like Larry says, you won't actually "short" the wire as it is a ground, not a power lead. So if you have a bare connection somewhere, you complete the circuit and the lights come on.
Just jiggle around up there and you should be able to spot the problem. It's pretty accessible, especially if you take out the glove box.
Dave F. in Rhode Island
'68 Camaro SS Accel DFI 454 (SOLD with no regrets)
Bought my first big-block Chevy in 1970
Similar Threads
Brake Pedal Doesn't come all the way back up- Lights stay on.. 1967rsss350 Troubleshooting 9 May 5th, 06 10:27 PM
69 Lights - what lights come on when? Frost Green 69 Electrical & Wiring 8 Oct 6th, 05 09:45 PM
68 Rs Interior Lights Stay On PLRS600 Electrical & Wiring 12 Jun 29th, 05 06:39 PM
no parking or hazard lights camaro man Electrical & Wiring 3 Jan 21st, 04 06:49 AM
Lights Causing Drain? Desert 68 Electrical & Wiring 3 Nov 19th, 02 04:10 PM
