 Ground Up Restorations
Second Generation 1970-1981
Old Nov 8th, 05, 02:33 PM
busterswt busterswt is offline
Default 327 in a 2nd gen
I've got a line on a recently rebuilt (near-stock) 1967 Chevy 327 casting number 3903352. I would want to put it in my 76 and bolt a Muncie M-21 behind it. Here are a few questions I have:
Can I bolt Vortec (062) heads on there without any problems (w/ correct intake)?
Can I use HEI ignition/distributor from a 350?
With the Vortec heads can I mount accessory brackets from a 350?
Any idea on compression ratio?
Thanks!
Old Nov 8th, 05, 03:10 PM
BPOS BPOS is offline
Al
Default Re: 327 in a 2nd gen
Can I bolt Vortec (062) heads on there without any problems (w/ correct intake)?YES
Can I use HEI ignition/distributor from a 350?YES
With the Vortec heads can I mount accessory brackets from a 350?YES
Any idea on compression ratio? Assuming a flat top piston with valve reliefs, a 4.030 bore, 64cc chamber,and a .045 quench, about 9.5:1.
Old Nov 8th, 05, 04:46 PM
Thanks for the reply!
What benefits, if any, does a 327 have over a 350?
Old Nov 8th, 05, 05:40 PM
pdq67 pdq67 is offline
Banned
Thumbs up Re: 327 in a 2nd gen
With a decent 270 to 280 solid lifter cam and no more than a cheap set of Z- type valve springs that fit the Vortec heads, you can hold her down as long as you feel safe before you shift!!
7,000 rpm easy.
pdq67
Old Nov 8th, 05, 10:20 PM
pdq67: hello from NastyZ28
I'm pretty stoked about this engine. It's about 240 miles from me and I'd be picking it up. How much less does it weigh compared to a 350?
Old Nov 9th, 05, 01:21 AM
TexasPerfProd TexasPerfProd is offline
Steve
Should be close one difference is the 3.48 stroke crank compared to a 3.25 Of course that also depends on what parts are inside. Just a example say one had aluminum rods ... it just lost alot of weight. Even lifters and piston design will have a effect on this but unless it has major work done on it it wont be much if any lighter than the 350.
Similar Threads
2nd gen dimensions BBCamaro Camaro Tech 4 Aug 23rd, 05 07:26 AM
2nd gen dimensions BBCamaro Body Shop 1 Aug 22nd, 05 02:05 PM
2nd gen Camaro/ Firebird question for a buddy Gideon Body Shop 0 Aug 3rd, 05 09:56 AM
4th gen in 2nd gen? Prelude00782 Interiors 4 Jul 13th, 05 04:03 PM
Could it be ? The very 1st 2nd Gen Camaro ? SS3964N8 Bench Racing 9 Jun 26th, 05 09:09 AM
