| Team Camaro Tech Current Topic: Computer Help - Windows XP | ||
| Bug Hunt Computer related problems Virus warnings - Technical help. |
My employer has just upgraded our desktops to XP. How do you handle Junk Email? I have tried a few things but still don't get the correct results. I copied my saved 'junk email senders list' into the XP Outlook file. It still doesn't recognize junk email on the list. I can manually add new junk to the list and it automatically moves it to the 'Junk E-Mail' folder but, how do set up a rule to automatically delete items in the 'Junk E-Mail' folder upon exiting Outlook?
I receive approximately 100 junk emails a day at work and dealing with them is becoming tiresome.
Dave, member number 7704. 1987 Grand National |
Who is your web hosting provider? The people who handle the email for your domain?
Most providers can turn on RBL filtering on their mail servers which will block 85% of the junk mail from ever getting into your mailbox. If your ISP won't do this for you (whoever handles your pop3 email) then you could use a locally installed program like SA Proxy or Mcafee SpamKiller to filter spam/junk. |
I have no idea. There are thousands of employees on the same email server.
Dave I feel your pain. I have had the same work email address for 14 years now and I get plenty of junk every day.
I have given up on trying to filter it out. Instead I write rules to let the good stuff in. Now this won't work for everyone , especially if you are in sales and get outside emails from new customers, but it works for me. Go to Tools, Rules and Alerts Click New Rule Click Start from a blank rule Click Check messages when they arrive Click Next Click Next (Which conditions do you want to check) Answer Yes to the dialog Click move it to the specified folder Click on the word 'specified' in the step 2 box and select the Junk E-Mail folder or whatever folder you like Click Next Now you should be at the Exception step Scroll down and click except if sender is in specified Address Book Click on the word 'specified' in the step 2 box and select your address book Click Next I named this rule Unexpected Click finish Just to summarize... this will move any email sent to you from an email address NOT in your address book to the folder you chose. Thus filtering out any unexpected emails. As for automatically deleting the 'Junk E-Mail' folder contents on exit you would have to use a macro for that. To use it you need to go to Tools, Macros, Visual Basic Editor. In the upper left corner of the screen you will have a Project1. Expand it and then expand 'Microsoft Office Outlook' and you should see a 'ThisoutlookSession'. Double-click the 'ThisOutlookSession' to get a code window up on the right side of the screen (may have already been there). Paste the following code into the code window (right side). Private Sub FolderNames() Dim objNS As NameSpace Dim objFolders, objFolder Set objNS = Application.GetNamespace("MAPI") Set objFolders = objNS.Folders For Each objFolder In objFolders MsgBox objFolder.Name Next Set objNS = Nothing End Sub Private Sub Application_Quit() Dim objItem As Object Dim objNS As NameSpace Dim objDestFolder As MAPIFolder Set objNS = Application.GetNamespace("MAPI") Set objDestFolder = objNS.Folders.Item("AshNDon").Folders.Item("Junk E-mail") If MsgBox("About to delete all items in the 'Junk E-Mail' folder.", vbQuestion + vbOKCancel + vbDefaultButton2) = vbCancel Then Exit Sub End If For Each objItem In objDestFolder.Items objItem.Delete Next Set objDestFolder = Nothing Set objNS = Nothing Set objItem = Nothing End Sub Click somewhere in the FolderNames subroutine and press F5. This will run the code and give you the names of the top level folders that exist. You will need to replace the 'AshNDon' in the Application_Quit event with the primary folder that you use for your email. Hope this helps. Donald Sr Software Developer Analyst from 8-5, 5 days a week [ 02-16-2004, 05:09 PM: Message edited by: MytMini ]
Donald 68 Camaro convertible (resto on hold - last updated 12/31/07)
Another handy thing I forgot to mention is that at the Excection step there is an option 'except with specific words in the senders address'. I use this as well so I can let anything from @xyz.com through. This would work well if you work a lot with a particular outside company and don't want anything sent from them to get lost.
I hope all of this helps...
You might ask the tech guys at AFLAC.COM if they will enable RBL filtering or have any plans to enable such filtering. This will be about 85% effective. To get another 10% effective they would have to start using some sort of Razor/Pyzor/DCC community filtering. Most corporations are enabling Spam Filters before their mail servers, it literally blocks about 80-85% of the email (yes that is how much is junk) and also usually will do full virus scanning as well.
I've deployed a few servers using Linux running MailScanner + MailWatch + SpamAssassin + ClamAV virus scanning. All the software is free (Open Source), only cost is the hardware which is about $800 and the labor to build the server and configure it properly which is about $500, then it basically goes in front of the mail server and accepts the email for the domain, if it passes the spam and virus checks its forwarded to the real mail server, if not its recorded in a database and deleted or quarantined. False positives are nonexistent when you set it up properly. With just 300 employees a company saves over $150,000 in employee utilization each year because of it freeing up not only the wasted time of sorting thru junk, but also the possible viral infections that can hit workstations as well. You might let your IS guys know about www.mailscanner.info, awesome product, I swear by it, and its FREE! |
