| Team Camaro Tech Current Topic: compression ratio | ||
Just a quick question here...what is the compression ratio on a 327/210? What will the compression ratio change to, if at all, with 64cc combustion chambers?
| Sponsored Links | ||
Advertisement | ||
The "advertised" comp ratio of a 210 is 8:1 (with 76cc heads)
Going to 64cc heads will raise it to 10:1 (advertised) in both cases, reality is probably a lil lower. The new heads will also have much bigger prots and intake valves, and I know from experience they will REALLY "wake er up!"
JimM's firstgens.com Camaro Board Jimragtop.com New website for my vert is coming together. Do ya like the slide show on the home page? |
I figure 8 to 1 CR. with a 76 cc head is about right..
A 210hp/327 is only 8.75 CR. stock, but I figure it had a 70 cc chamber head on it?? Only thing is that ROSS Racing Pistons CR. calculator figures it at 8.94 CR. with .020" thick shims vs .038 composites at 8.61 CR. so I don't know? 64 cc heads with .020" thick shims create's 9.55 CR. and the .038 composites create 9.16. Anybody else know what pistons a 210hp/327 had in it?? Flat-tops with -5 cc, 4-valve notch?? And shims or what?? I know the info is here somewhere?? pdq67 PS., info I used; 4.00"b x 3.25"s, down-in-the-hole = .025", .020" and .038" headgasket thicknesses and -5 cc valve notch volume on true flat-top pistons. |
the 210 (and the 275) came with 4 eyebrow flat tops, -7.1 cc's.
And I think you're right, Paul, the advertised comp on the 210 is higher than the 8:1 I said, maybe 8.5? The stock heads are 76cc.
You guys are just a wealth of knowledge, thanks much
| Sponsored Links | |
Advertisement | |
