| Team Camaro Tech Current Topic: What cam solid SBC? | ||
I am currentley building a 406 sbc for my camaro-Have shortblock done has flattops and stock crank and rods arp . I just bought aset of heads and can't find any info on them-There world products sportsmans supposedley 64 cc angl plug 202 160 with 200 intake runners! I bought them from a machine shop ready! Sorry for the long post-AM NEW HEAR MY 1st post! Im don't spell well so bear with me! My car has 456 gears and turbo 350-3200 stall-I need a good proven solid cam-looking at midwest cams-Would like to run 11.50 1/4 turning no more than 6200 rpm's! Thanks if anyone can help! Like this sight!
| Sponsored Links | ||
Advertisement | ||
I went with an Isky solid Z30 on a 383 with similar heads and pistons as yours, and it definately wanted more cam! It was advertised as having a "lopey" idle, but it was very smooth. I was dissapointed in the idle quality. So your 406 is going to want a lot more cam.
heres what i use elgin 556 533 lift 264 256 at ,050 i run neally the same combo as you are and you see what my chevelle ran with that set up.they make it in a small base circle also .i shift at 6200 and go thru the traps at about 6500.i always got mine from compition products .there are alot of manurfacturer that make the very same cam.ive also put a elgin 525 lift 250 duration at .050 in my brothers car it worked pretty well in his with a 406 in a street car with 411s and a turbo.i also changed to a solid roller 615 lift at 260 dur, and didnt pick up one bit in the 1/8th mile from the elgin .it did lighten my bill fold a little though
67 NOVA 406 best 6.789 in 1/8th 1.437 60ft at 99.26 mph 66 chevelle 406 best 7.12 in 1/8th |
im not sure what size tire you are running but if its a 28or 26 inch you will be turning more than 6200 with 456 gears in the 1/4 mile.
Plan on running race fuel -- your compression ratio will be approx 11.5:1 with 64cc heads and flat tops in a 406.
With a 3200 converter I would look for a cam with 240/248* duration @ .050 on a 110* lobe separation. That should make a power band of about 2500 - 6200 RPM. Your cylinder pressure will be high so detonation could be an issue if you don't run 110 octane. You should be able to run mid - 11's no sweat if the car will hook up.
E85 racer and E85 carb builder www.horsepowerinnovations.com 68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle |
Crane Soild Cams PN#111431 F-260 260/268 @.050 .554/.574 106 LC
If lift is a problem then then try the Chevy 1st design Off Road cam listed in Crane's catolog as a Muscle car cam Crane Solid Cams PN#968821 Off Road 257/269 @.050 .493/.512 112 LC works good with nitrous. Other choices that work good- Isky PN#201070 Z-70 264/264 @.050 .548/.548 108 LC Isky PN#201065 Z-65 272/272 @.050 .560/.560 108 LC works with nitrous
Brotherhood of Street Racers |
How about this camshaft- 252-256 at 50 deg. 542-553 lift- lobe separation 102-Also running 10.5X28 slicks-have access to Super vic intake and RPM-Should I change the 456 gears to 373's? Iam thinking the 456's are too much!
with a 3200 stall and <6200 RPM redline you need to keep the cam down in the 240's @ .050 with the wider LSA IMO
Hate to say it, but this combo is mismatched a bit -- either get a looser converter and put a cam in to spin it more, or find a way to get the compression down. Just my opinion.
I would make some changes if at all possible. The biggest issue is that the compression and rear gearing are just screaming for a big ol bumpstick.....but the heads and the coverter dont agree....plus your rev limit doesnt fall in line with anything much bigger than low 240 duration at .050. If you put in a gaint camshaft, you cant expect those heads to keep up without work......and even if they were perfectly capable of keeping up to anything you throw at them....you cant expect to make the big power with a big cam if your gonna cut it off at 6200rpm cause of course, a huge cam will want to spin and make power at higher rpm. I was figuring on around a mid 240 degree cam at best to compliment the heads.
As far as the cam, the lunati 401A6 looks good. Its numbers are 243/251 at .050, .518/.530 lift and a 110LSA. There are others that fit the bill but I wouldnt be going any bigger unless your ready to spin higher to make power cause a bigger cam will need to. This one will like to rev enough itself. As is, any headwork you can muster up will help your cause a LOT....and the bigger the cam, the more this really becomes something that should be done. With that cam, the compression will still be a bit much. Dont expect to run pump gas unless this turns out to be one of those happy accidents that does somehow(happens sometimes) but the numbers dont say so. I figure if you arent going to make any other changes, youve gotta compromise somewhere and it would be better to have a little too much compression and have to put some real fuel in her than to have too much cam and not be able to spin nearly high enough to allow the big cam to make power. Unfortunately, I just dont think a motor like this would have 11.50's in it. But, I also dont think putting in a bigger cam will save it. Youd need to make other changes. If you are willing to do so, get some good cylinder head work done. Thats a premium. Step up the converter to something more like a 3500-3800 converter and a cam of around 248/258 at .050 and a 108-110LSA could do it with the gears and compression. However, youd have to deal with the fact that it will want to run 6500 plus rpm. |
#11
406 combo was 10.17:1 TRW dished pistons,CC280H Cam (.486I/E 110LSA)Torker intake,72cc Protopline Iron Lightnings with 2.05/1.6 valves,th350 ,12" 2200stall,3.73 gears 27.5" tall McCreary's and ran a best of 12.5@110.
I went to a Vic Jr. and 10" 3000 stall - went to track and had traction issues (never hooked) but program shows 11.9X's. I just bought a CC305H (.525 I/E) and program claims mid-low 11's. But I have to tune what I'm running before the cam swap, too many changes at one time and got lost.
68 Camaro~ LSx RedЯum <-Pics http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here |
#12
I'm going with the Isky Z-35 for my 383. I've heard that it sounds awesome and runs better than it sounds. I'm planning on a high winder too with 4.56 gear.
Marty Lake 1969 Z/28 fathom green X77 |
#13
And with the SpII heads, work on the exhaust ports will help a lot. I hear that those heads respond well to unshrouding the exhaust valve in the chamber which would also help reduce your compression ratio a hair.
#14
76 the max gear for the 1/4 mile with your rpm limit would be 411s i would think but the 373 would be alot better than the 456 unless you are gonna run the 1/8th mile.make sure no matter what cam you go with that the valve springs will take the lift of the cam with out coil bind.your next step if your gonna just race it would be the coverter
#15
Funny someone mentioned the 305 comp hyd cam-I actually have one on the shelf-My springs have 140 lbs though that are set up for solid in about 550-560 lift-might wipe a hyd out! So many different opinions on cams and I understand why weight converter gears etc> Interesting replies though-definetley a good subject and I appreciate the input so far!
| Sponsored Links | |
Advertisement | |
