Best carb combo for 396 big block - Team Camaro Tech
Thread Tools Display Modes
Old Nov 30th, 05, 08:59 AM
Lol_uk's Avatar
Lol_uk Lol_uk is offline
Laurence
Default Best carb combo for 396 big block
I have a 68 camaro with 396 block, and am replacing a Torker 2-O (with a Holley double pumper- size unknown) with a new Edelbrock performer manifold. I am guessing the Holley is a square bore carb...so any suggestions for the best replacement would be great! I have a 3.55 rear gear to install- not sure what's in the engine!...roller lifters and cam I think (huge Edelbrock valve covers!) oval port heads...and I want it as a quick street car, so streetable is the goal.
Any advice appreciated
Lol
Old Nov 30th, 05, 12:19 PM
oger oger is offline
Default Re: Best carb combo for 396 big block
The Performer is drilled for both spread and square bore carbs. I would use a Q-jet but a lot of people like a 750 vac.
Old Nov 30th, 05, 12:24 PM
Lol_uk's Avatar
Laurence
That's great...I didn't know I could use that carb on the new manifold without a conversion plate. Thanks so much for the info.
Old Nov 30th, 05, 02:54 PM
Straight-line-69 Straight-line-69 is offline
396's and Q-jets work beautifully together!
Old Nov 30th, 05, 04:04 PM
pdq67 pdq67 is offline
Banned
Thumbs up Re: Best carb combo for 396 big block
I don't know what hp your 396 is so don't know if it is a 10.25 or an 11 to 1 CR. motor or not??
BUT the great old 750 cfm, Holley 3310 carb. was made for a stock 11 to 1 CR., 375hp/396 motor!!
I bet it and an RPM intake would do you nicely AND I AM a Q-Jet guy!!
pdq67
Old Nov 30th, 05, 08:06 PM
SIDEWAYS SIDEWAYS is offline
770 Avenger is hard to beat!
VINCE
69 CHEVELLE SS
502 EFI/[224/228 HR]/T56/3.90
*1.8/11.59/124.34*
Old Nov 30th, 05, 11:06 PM
Lol_uk's Avatar
Laurence
Thanks for the advice...I was going to try out the Holley double pumper (carbs are expensive to get hold of in the UK!)...but if gas consumption is outrageous I guess I should go for a carb with vac secondries?
The car runs on unleaded pump gas, so I'm guessing compression ratio must be lower than 10 to 1.
Would I need to get a specific q-jet for this?...the guy who is doing the work is a Pontiac man..has spare q-jets taken from Trans ams/ firebirds etc- would they be useable?
Old Dec 1st, 05, 05:13 AM
Banned
Yes, I figure a Q-Jet off either a 350 or 400 Pontiac motor should do nicely..
But I also igure that you will need to make sure that the top butterfly's tip in the way you want them as well as check and see if it opens 100 percent on the back barrels b/c the early 'Bird carb's didn't b/cthey didn't want the 'Birds motor making the same power as the Leader GTO!!
pdq67
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Best carb combo for 396 big block
Location
Location
First Name
Human Verification
