holley 670 street avenger secondary springs - Team Camaro Tech
Thread Tools Display Modes
Old Dec 10th, 05, 03:04 PM
importkiller69ss importkiller69ss is offline
bryan hall
Default holley 670 street avenger secondary springs
i have aholley 670 in my 69 ss 350 . i was looking to upgrade the springs but dont know which one ot go with. what springs come in these from holley? and which springs are the best for all around streetabilty and performance? do changing the springs really make much of a difference or am i wasting my time tryin to change them
Old Dec 11th, 05, 07:36 AM
SLEEPER 86 SLEEPER 86 is offline
Default Re: holley 670 street avenger secondary springs
pretty sure holley's website has the opening rates vs. color chart.
Eric B
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
Old Dec 11th, 05, 09:00 AM
67 Prostreet 67 Prostreet is offline
The springs most certainly make a difference... Just changing springs helped find the last 12hp on the dyno for the 383 in my wife's convertable. I used the lightest spring Holley makes to get the secondaries open sooner. It all depends on how you want the car to react. Lighter springs will open the secondaries sooner and you will see and feel the performance, however it comes at the cost of economy. Believe it or not, some guy's will setup the secondaries to come in late to save on their fuel bill at the cost of performance. It all depends on what you are looking for?
Regards,
Tom
1967 Prostreet Camaro BBC TH 400 w/4,500 stall 4:56 gears,narrowed and tubbed...
1969 Convertable RS Clone 385 TH 400 w/2800 stall 3:73 gears
1966 Pontiac LeMans... Soon to be a GTO clone.
Old Dec 11th, 05, 09:24 AM
TJS69 TJS69 is offline
Tom
Smile Re: holley 670 street avenger secondary springs
The springs can be bought in a kit, that has all springs. Buy the kit and you can try them all ! (If you want). I believe the avenger series carbs have the "quik change" spring, so easy to do !
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Dec 11th, 05, 11:02 AM
WaynesWorld WaynesWorld is offline
I have the same carb. It came with a couple other springs. I swapped out the silver "best performance/economy" sping and used the yellow "increase performance" spring.
very EZ to do.
-Wayne
67 Camaro
Old Dec 11th, 05, 11:32 AM
bryan hall
thanks guys....i will look into to changin those springs
Old Dec 11th, 05, 11:51 AM
DjD's Avatar
DjD DjD is offline
Dennis
From Holley -
The opening rate of a vacuum secondary system is controlled by the diaphragm spring located in the vacuum secondary diaphragm housing. A “lighter” spring will allow the secondary throttle plates to open more quickly. A spring assortment kit, Holley P/N 20-13, is available to help you “tailor” the secondary opening rate to your application.
From my Holley carb book by Urich & Fisher
Using a 350 CID Engine
Spring------start to open------ full open
Short Yellow--1620-------------5680
Yellow--------1635--------------5750
Purple--------1915--------------6950
Plain----------2240--------------8160
Brown--------2710--------------8750
Black---------2720-------not fully open at max air flow
These rpm numbers go down as cubic inches go up and an air cleaner causes these numbers to go down as well... There was no air cleaner used when they tested this.
To find the right spring, start with the plain one and test drive. If you feel the sec's kick in when you go wot they are opening too soon. If you don't feel a kick in then try the next lower spring. If you feel the kick in go back up one. You get the idea...
Not feeling the sec's kick in may seem wrong but on-track testing has shown if you feel the sec's open you are running slower with a vac sec carb...
...Dennis
www.camaroslimited.com
Old Dec 11th, 05, 11:56 AM
edd Gordon edd Gordon is offline
Edd
I got same 670 on my 406 68 SS the secondaries do come in late with stock springs but I don't think I will change it as it runs great and fuel mileage (all though not checked yet) doesn't seem bad and spark plugs are burning just right color and the performance is not bad feels like it could be a mid 13 second car with some tuning. I have only got 300 miles on it and will see if the carb needs tuning after engine is broke in.
Edd Gordon 68 Camaro SS350 now SS 406 96 SLP SS Camaro
Team Camaro Tech > All Generations > Performance      Current Topic: holley 670 street avenger secondary springs
Location
Location
First Name
Human Verification
