 Ground Up Restorations
Second Generation 1970-1981
Old Dec 22nd, 05, 05:37 PM
jethro67 jethro67 is offline
Default 72 Z 28
Just Got Back At Looking At 72 Z With 35 Lt 1 Rock Crusher
Trans 12000 Original Miles But Needs Alot Of Work. My Question Is How Do I Make Sure The Numbers Match?
Old Dec 22nd, 05, 05:45 PM
Dayton68Z28's Avatar
Dayton68Z28 Dayton68Z28 is offline
Gold Member
Dayton
Default Re: 72 Z 28
Here is your best source for 2nd gen camaros,http://www.nastyz28.com/camaro/camaro72.html
1968 Z/28
1969 Pro Touring
Old Dec 22nd, 05, 06:25 PM
Default Re: 72 Z 28
correct me if im wrong but does that site read they only made
2575 72 Z28
Old Dec 22nd, 05, 06:44 PM
Default Re: 72 Z 28
correct me if im wrong is this site saying they only made 2575 z28
Old Dec 22nd, 05, 07:01 PM
pro1 pro1 is offline
armin
Default Re: 72 Z 28
Probably correct number.........GM had a big strike then........i believe almost 5 months
Old Dec 22nd, 05, 07:17 PM
radial72 radial72 is offline
Default Re: 72 Z 28
Rare in this case doesn't translate into more valuable. It IS a desirable car (any 70-73 Z28 is desirable) but in most cases a similar 1970 Z28 will be worth more, and this is from someone who has owned a '72 RS/SS 350, and an '72 SS 396 (which is really rare), but when it comes down to it, the '70 just finds more willing buyers. That said, I've always had a soft spot for the "stepchild" '72's, and the '72 Z28 is something I'll own eventually (came close this summer, but the car was too rusty! If I run across another I may just have to buy it). That said, it is a great car to drive and a wonderful car to own.
Numbers matching? Well, first get them off the block, trans and rear, there are also date codes on other parts (which should be present if it really only has 12K, unless it was a 1/4 mile at a time) but those are the big 'uns. Lots of places to decode them on the web!
Old Dec 22nd, 05, 08:07 PM
dyno jonn dyno jonn is offline
Jon
Default Re: 72 Z 28
And be sure to check out the rear unibody ?subframe? for rust through behind the rear floor to where it goes up toward the trunk area. Those year Camaros were sorta bad about that.
Jon N.
At the back of the Daylight Saving scheme I detect the bony, blue-fingered hand of Puritanism, eager to push people into bed earlier, and get them up earlier, to make them healthy, wealthy and wise, in spite of themselves." Robertson Davies
