Tech 2000 Our previous General Forum
Replies ONLY - no new topics.
Old Oct 6th, 99, 03:39 PM
Silver69 Silver69 is offline
Default
I have a '69 Camaro RS/SS with a 396/325 hp. It has a Quadrajet carb, as it should. Can I install a Holley carb and retain the original fuel line to the filter/return set up on the front of the motor? Will this configuration work OK?
Old Nov 1st, 99, 08:25 AM
Rob.Canada Rob.Canada is offline
Default
I went the other way from a Holley Spread bore carb back to the Q-Jet, If you pick up the right Holley carb every thing should line up. Whoever put the Holley on my car got the right unit, the linkages and fuel line matched perfect. I didn't like the Holley, It always seemed to load up in city driving and sucked the juice right through on the highway.The Q-jet works fine, for normal cruising.
Old Nov 6th, 99, 04:20 PM
Default
Thanks for your help. Eventually, I do want to go back to the complete Q-Jet set up.
