| Team Camaro Tech Current Topic: 67 RS headlight motor wiring | ||
| Tech 2000 Our previous General Forum Replies ONLY - no new topics. |
My headlight motors are not working correctly. When you turn on the lights, the doors barely move and then stop right away as they release the button on the relay. Where can I find the correct wiring diagrams? Thanks, Jeff.
JEFF
Did you get your head light problem fixed?, or do you still need help?. |
I ended up pulling wires on and off the connectors and then they started working properly. It may have been a grounding problem. Thanks anyway.
JEFF,
GLAD TO HEAR YOU GOT YOU'RE MOTORS WORKING. CLASSIC INDUSTRIES SELLS A WIRING DIAGRAM FOR THE 67 RS HEADLIGHTS. IT SAVED ME, YOU MIGHT WANT TO GET ONE JUST IN CASE YOU EVER NEED IT. JUST TAKE A LOOK AT THE TANGLE OF WIRES AND RELAYS UNDER THE LEFT FRONT FENDER AND YOU WILL UNDERSTAND WHY. THESE CONTROL THE OPENING AND CLOSING OF THE DOORS ALONG WITH THE LIMIT SWITCHES. THE BOOKLET ALSO HAS CENTER CONSOLE GAUGE WIRING DIAGRAMS IF YOU'RE CAR IS EQUIPPED |
