 5thgen.jpg - 4890 Bytes
Fifth Generation Discussion forum for the newest Camaro
Old Jan 10th, 06, 10:56 PM
Tokyo Torquer Tokyo Torquer is offline
Default 2009 Camaro Concept
You guys seen the 2009 Camaro Concept?.. I don`t think they did as good a job as the Mustang or Challenger retro cars. Especially the nose of the car..but it does look mean, nevertheless.
http://www.ls1lt1.com/forum/showthread.php?t=2454
http://www.ls1lt1.com/forum/showthread.php?t=2468
http://automobilemag.com/auto_shows/...amaro_concept/
even a video..
http://ls1lt1.vidiac.com/Player.aspx...B-C174CE5DCA0B
1973 RS Z28: 401ci Dart Little M, Littlefield 6-71 supercharger @14lbs boost, Callies Magnum crank, Lunati rods, JE pistons, 7.8:1, AFR 227 Comp heads, T&D 1.6 shaft rockers. Reed solid FT cam (240/250@.050-.523/.542 lift-112 LSA), QFT 750 carbs
Old Jan 11th, 06, 01:28 AM
JWA JWA is offline
Gold Member
Jeff
Default Re: 2009 Camaro Concept
Might want to look at the 5(at least) other threads in Bench Racing on this car.
Addicted to projects... I just wanna drive........
Old Jan 11th, 06, 08:44 AM
1FASTZ 1FASTZ is offline
Here are the styling cues that I see. Front fender looks like it came from a 3rd generation camaro. The door looks like its from a 68 and the quarters look reminiscent of a 69 with the gills or whatever they are called. Personally, it hurts me to say this, but I like the looks of the Challenger a lot better because I think it looks more retro. And let me make it clear that I am absolutely not a Dodge fan, not that there's anything wrong with being a Dodge fan (wink..wink).
Marty Lake
1969 Z/28 fathom green X77
Old Jan 11th, 06, 09:01 AM
clwilcox33's Avatar
clwilcox33 clwilcox33 is offline
Christropher
Can't we keep discussion of the concept car under one or two threads?
Christropher
1967 RS/SS 350...in pieces still.
http://www.67rs-ss.com/
**How to attach images**
MrDanB - "Don't worry about Mr.Wilcox...He has that incurable disease of thinking that they only made the Camaro in '67 "
Old Jan 14th, 06, 12:47 PM
arocars arocars is offline
Hey, Cool, A new Mustang with Camaro slyling cues and emblems.
The Challenger definitely looks better. For that matter, so does the Mustang.
Old Jan 14th, 06, 02:17 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
We are moving all the Concept Camaro threads to the 5th Generation section, trying to keep them bundled up. If someone just comes into Bench they wont notice the 5th Section yet but we will try to keep up.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto.
Our Camaro Webpage
Photos for viewing
Learn How To Post Pics here
Old Feb 2nd, 06, 02:37 AM
big block camaro big block camaro is offline
Where Will It Be Built ? The Usa Or Japan
Old Mar 17th, 06, 07:55 AM
Chris 96 WS6 Chris 96 WS6 is offline
Hi guys.
LS1LT1.com is my site, I saw Camaros.net as a referrer for a few visits so I thought I'd check you guys out.
I've also started a site called http://www.5thgen.org that is keeping up with all the latest news about the concept, production timelines, where it looks like it will be built, etc.
I recommend bookmarking and checking in there every week or two as I google and yahoo search for news articles daily. As soon as GM give the official word they're building it, I'll have the story posted.
Old Mar 17th, 06, 11:38 AM
newmexguy newmexguy is offline
the new concept is neat, but it would be even better if the exact dimensions of the 69 model was used, with modern construction underneath, i.e. rack and pinion steering (manual available) five and six speed manual trans, the vortec 4.3 iron engine workhorse as the base engine, and a solid rear axle. If a unitized construction were used, the weight penalty and compromises of the original subframe design would be eliminated. IRS (independent rear suspension) might be nice for the top of the line SS? or Z-28? optioned cars, but a simple leaf sprung rear or four link would be fine. No torque beam or converter floor hump, please.
Old Mar 17th, 06, 11:45 AM
I really hope GM rethinks the design and gets it closer to the original camaro..WE WANT MORE RETRO! Not that the new design is bad, but it does nothing for me at all as a "camaro" where as the new Dodge gets my blood pumping and I am not a Dodge person.
