Third Generation 1982-1992
Old Jan 17th, 06, 07:23 PM
one wheel peel one wheel peel is offline
Default 84 rear end swap?
what rear end would swap in to a 84 camaro?is there anything out there that willwork?i have 3.42 gears and i have a rear end from a 87 blazer with 4.11 posi will it work?can i swap carriers?
Old Jan 17th, 06, 08:15 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is online now
Team Member
Scott
Default Re: 84 rear end swap?
That might work, I think they both had 7.5 setups. Although it might be easier just to get a rear form a 3rd or 4th gen. Try thirdgen.org
pro1 pro1 is offline
armin
yes the gears and carrier will fit in your housing
Old Jan 17th, 06, 08:54 PM
chadrafuse chadrafuse is offline
Tech Team
yup they will.
Old Jan 17th, 06, 11:51 PM
big gear head big gear head is offline
Freddie
Is this a full size blazer or an S series blazer? If it is an S series then it will probably work, but if it is a full size then it will not work.
Moser Engineering Dealer
'69 RS/SS396 pro street/427/4spd/9"
http://www.camaros.net/showroom/show...00&ppuser=1922
