 Ground Up Restorations
Second Generation 1970-1981
Old Jan 21st, 06, 06:34 PM
rivieragransport rivieragransport is offline
Tech Team
Default 70 Z information needed
Hey all...do all 70 Z's say Z28 or 28 on the trim tag? Or was it a Norwood and Los Angeles thing. I have run across a car a guy claims is a Z (LA built car) but nothing on the trim tag...thanks!
Old Jan 21st, 06, 07:11 PM
69 ss hugger 69 ss hugger is offline
Mike
Default Re: 70 Z information needed
Yes the trim tag should say z28 on it. but 1 thing to look 4 is the gas pedal should b bolted to the floor only 70 z28 did this.
Old Jan 21st, 06, 07:22 PM
Mike
If u would like to learn more about 2nd gen.camaros go to www.nastyz28.com
Old Jan 21st, 06, 08:28 PM
pro1 pro1 is offline
armin
A Norwood Car Can Either Say Z28 Or Just 28 On The Tag.mine Personally Says Z28 And 2 Others Locally Say Just 28.these Are All Canadian Documented Cars.......2 With Column Shift/no Consol
Old Jan 23rd, 06, 11:14 PM
Tech Team
I looked at nastyz28.com and they say LA built 1970-71 Z/28 do not say Z/28 on the trim tag...only Norwood cars do. Does that sound right?
Old Jan 24th, 06, 07:12 AM
softail02 softail02 is offline
Keith
thats correct
Old Jan 24th, 06, 07:15 AM
Keith
thats correct.. there are a few things to look for that are easy to fake and not so easy...lookat the front lower control arm and look for aluminum blocks under the rubber stoppers very hard to fake and very offen forgotten about. Visist my hompage and drop me a note if you need some help ... I love 2nd Gen
Old Jan 24th, 06, 08:50 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Team Member
Scott
There was a guy at nasty z that was making them, I am not sure he still does.
Link to your home page, please?
Old Jan 25th, 06, 08:12 AM
Keith
www.racealley.com
Old Jan 26th, 06, 09:44 AM
al8apexer al8apexer is offline
go to www.nastyz28 for 2nd gen info
NONE of the LA built cars say anything toi link them to a Z28 on the trim tag
however ALL z28's have the above mentioned alum spacers (although this was a well known fact during the 70's and a LOT of owners upgraded their SS with this part
ALL 70-71 Z28 have the "truck" style gas pedal that is hinged at the floor and attaches to two studs that go through the floow
ALL 70-72 Z have the 8k tach as well as the small rear bumper guards
IF an auto the trans is a Turbo 400, ONLY avail with the Z and the 396 cars
Jim Rohn
Scottsdale, AZ
70 M22 Z28
34 Ford original
Old Jan 26th, 06, 09:13 PM
Tech Team
thanks guys...
