Oil pressure sender location on small block - Team Camaro Tech
Thread Tools Display Modes
Old Jan 23rd, 06, 05:56 AM
jm69ss jm69ss is offline
Angry Oil pressure sender location on small block
Where can I install the oil pressure sender on a 350 small block? This is one of the things I didn't think about prior to installing the motor. I usually install it just above the oil filter, but the allen head is stripped on the plug and it is almost impossible to get to with headers installed. After a couple of frustrating hours trying to get this $#@%$#@ plug out I gave up. I really don't want to pull this header again (another story). What are my choices? Below distributer? Any other locations?
Thanks.
JM69SS
1969 Azure Turquoise, 350/350 - Sold
1973 RS Z28 (New toy!!)
Old Jan 23rd, 06, 06:10 AM
69ss350 69ss350 is offline
Default Re: Oil pressure sender location on small block
Another port is located behind the distributor, right on top the main block rail (where the intake seals to the block), towards the drivers-side. This is the port used for cars with center console oil guages.
You'll have to take the distributor out to get to it.
Old Jan 23rd, 06, 08:49 AM
GreyShadows GreyShadows is offline
Kyle
Yeah and its a big pain but i used a small brass extension((about an inch) on mine with a 45 degree elbow and now its nice and easy to get at
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
http://www2.snapfish.com/slideshow/A...71/t_=88171671
Old Jan 23rd, 06, 08:59 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Scott
That is what I did for my 93 K1500 (4.3, but essentially the same as a SBC) when the fitting broke trying to remove the bad OE sender. An autoparts store should have a selection of small brass fittings.
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NastyZ28 ... NJ Camaros & Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
TC Member #13
Old Jan 24th, 06, 05:24 AM
Hey guys, there is an 1/8" npt plug in the front of the block, in between the timing chain cover and the intake. Looks like an oil valley to me. It is even clearanced around it like it was made for the sender - it fits perfect. Any reason why I can't use this location? It sure would make life easier.
JM69SS
Old Jan 24th, 06, 09:36 AM
Kyle
I believe that the only outlet on the ol chevy 350 blocks that will give you an accurate oil pressure reading is at the rear by the distributor but i could be wrong
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4:11 POSI
Old Jan 24th, 06, 10:52 AM
One thing I left out is that this is a mid 80s truck block if that matters.
JM69SS
Old Mar 30th, 06, 12:50 PM
Go69 Go69 is offline
One thing I've noticed about that 1/8" plug at the front of the block-every 4 bolt main block I have ever owned has had that plug there. A couple of 2 bolt blocks I have owned did not have it.. Is this another indication of which blocks might be 4 bolt mains without tearing them down to find out?
1969 383CI, T-56, 12 bolt-3.31 posi, 13" C5 Rotors, PBR Calipers, rear disc system..
Old Mar 30th, 06, 01:23 PM
Steptoe Steptoe is offline
Steps
I connect below the Dizzy port....I used a Tee one to the consol gauge, the other with pressure switch to the dash warning light.
I have the same for water temp using sensor by the water neck and the other in the head.
Its all very well having gauges, but if something goes wrong, there is nothing better than a RED STOP light come up on the dash also.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Oil pressure sender location on small block
Location
Location
First Name
Human Verification
