Floor pan replacement - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Feb 1st, 06, 03:55 PM
rsbecool's Avatar
rsbecool rsbecool is offline
Rene
Default Floor pan replacement
Who makes the best floor pans?
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
Old Feb 1st, 06, 04:03 PM
pro1 pro1 is offline
armin
Default Re: Floor pan replacement
dynacorn
Old Feb 2nd, 06, 06:46 AM
rsbecool's Avatar
Rene
What would be the difference between Dynacon and say Goodmark?
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
Old Feb 2nd, 06, 07:27 AM
GoEjrGo GoEjrGo is offline
Joe
I would say that Dynacorn is USA made and Goodmark is Taiwan but I am not sure. Go with the USA made. I bought a set from Classic Muscle in Winston Salem, NC. After buying the imports first I switched them out for the USA made. Whole lot better stamping. I am not sure who made them though.
Joe
1967 rs 327/4sp Nantucket Blue - Someday!
My 67 RS
Old Feb 2nd, 06, 08:10 AM
kmarron kmarron is offline
Do you have a web address for them? I am also looking to do trunk and floor pans in my 67.
Old Feb 2nd, 06, 09:45 AM
Joe
Here is a link to their home page.
http://1967-81camarocarparts.com/index.html
Joe
My 67 RS
Old Feb 2nd, 06, 10:28 AM
z10kl z10kl is offline
Keith
Dynacorn is imported also. But if you need the full pan its the way to go. Generally if it is the repo metal coms with black Ecoat it is imported. US is bare metal.
Old Feb 2nd, 06, 11:57 AM
Ghostbuster's Avatar
Ghostbuster Ghostbuster is offline
Team Member
Tony
Dynacorn is a US based company that recently bought the original molds and presses from GM. (They do have a sister plant in Canada.)
http://www.dynacorn.com
You can now order a tubbed '69 convertible for around 10k.
HotRod and several mags have done recent write-ups.
They recently closed their legal battles with GM over selling new 1st gen parts, vs. selling new 1st gen cars, interesting read..
I bought and installed a Dynacorn full floorpan.
GREAT FIT.!
I have never done anything like this before.
It had notches that matched up with my rockers and firewall.
They even had the cut-outs for slide bolts, used to hold the rear leaf spring receiver.
Goodmark has done a great job refabbing for years, but use their "reverse engineered molds"
http://www.goodmarkindustries.com/
Both are authorized GM replacement parts, but I'd recommend a Dynacorn reseller.
www.ColoradoCamaro.com
68 AIM (600mb)
Old Feb 3rd, 06, 03:11 PM
rsbecool's Avatar
Rene
Thanks for the feed back looked at the web sites for both products looks like their both good.
68 rs 350
M-20 4-speed
10 bolt 8.5 3.23
Old Feb 6th, 06, 08:11 PM
Leadfoot1 Leadfoot1 is offline
Mario
Ghostbuster,
When you said you used their complete floor pan...I see your front and rear (trunk) complete floor assemblies but i also see that they are already assembled???? Did they come like this? I knew the floor (cockpit) was available as 1 piece and ditto for trunk but not that they we're available already stitched together?
Also, you seem to be using weld in subframe connectors, will you change your frame rails for weld in model that goes with the frame connectors?
Did it really go that well replacing the 1 piece floor? Did you use braces or just level the car, remove and replace?
Thanks for your input!
Lead.
LEADFOOT1
'Still a 1969 Camaro, but now a 1 owner 63 000 miles stored since 82 Convertible! Complete C6-Z06 Brake set-up, DSE Frame conn,19x8.5" and 20x13" Gunmetal-FORGELINE ZX3p's w/345-25-20's P-Zero in full tubs.
AirBar Suspended!
  #11
Old Feb 15th, 06, 05:27 PM
Team Member
Tony
Cool Re: Floor pan replacement
Originally Posted by Leadfoot1
Ghostbuster,
Lead.
I purchased a complete floorpan, a trunk pan, new rockers, weld-in rear frame rails, floor braces, etc..
I welded them all together to build my rolling chassis..
(check out my profile image..)
I completly dismanteled the car and started building from the ground up..
My car was so rusted, I thought this would be easier and straighter.
Here is a pics of the assembly process, (notice the clamps, not welding yet)..
68 AIM (600mb)
  #12
Old Jan 26th, 09, 06:57 PM
ls427ss ls427ss is offline
Larry
I know that this is an old thread, but while looking for floorpan threads I found it and had to lol... Here is the tag I just took off my Dynacorn floorpan, I assume it's Taiwan Minnesota? lol
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ProStreetCamaro.com
68 Camaro project photos
  #13
Old Jan 27th, 09, 05:41 PM
chevy 67 chevy 67 is offline
maxwell
i also used dynacorn,fit very well. they don't come with the front seat risers i reused my old ones. full trunk floor is from them too.
i dont think its worth buying the unit together. its 2x what i paid for mine in 2 parts.
  #14
Old Jan 28th, 09, 05:46 PM
jmkiv1515 jmkiv1515 is offline
Tech Team
JIm
I have been reading all of the posts, good information here. I wanted to ask a quick question, the floor pan has 4 holes in it. 2 on each side, however under the rear seats, the center, and the front seat brackets are fine. Would it be easier to replace the two sides or just replace the entire floor pan? The full floor pan is a lot more expensive than purchasing just the left and right sides. I was wondering which would be the easier and cheapest labor wise?
  #15
Old Jan 28th, 09, 05:54 PM
NHBandit's Avatar
NHBandit NHBandit is offline
Mark
Easiest & cheapest would be the seperate pans but be aware that once you start getting into it you may find more rust. You'll also have to reuse the seat brackets if you go that route. I believe some of them come already installed on the complete floors.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Floor pan replacement
Location
Location
First Name
Human Verification
