'69 Camaro Weights - Team Camaro Tech
Old Feb 3rd, 06, 06:15 PM
JohnZ JohnZ is offline
Team Member
John
Default '69 Camaro Weights
At David's request, here are '69 Camaro standard-equipment model weights, with the net add or subtract effect of each option:
6-cyl. Coupe: 3005
8-cyl. Coupe: 3135
6-cyl. 'Vert: 3255
8-cyl. 'Vert: 3385
A31 Power Windows +19
A67 Folding Rear Seat +38
C06 Power Top +8
C08 Vinyl Top +6
C60 Air Conditioning +97
D80 Spoiler Equipment +7
J50 Power Brakes +11
J52 Front Disc Brakes +26
JL8 4-Wheel Disc Brakes +97
L22 155hp L-6 Engine +17
LM1 350/255hp Engine +86
L48 350/300hp Engine +86
L35/34/78 396 Engine +249
U63 AM Radio +8
U69 AM-FM Radio +10
U79 Stereo Radio +17
M11 Floor Shift Control +9
M20 Saginaw 4-Speed +16
M20/21/22 Muncie 4-Speed +4
M35 Powerglide with V-8 -5
M35 Powerglide with L-6 -10
M38 THM-350 Transmission +23
M40 THM-400 Transmission +57
MB1 Torque-Drive Trans -17
MC1 H.D. 3-Speed Trans +31
N40 Power Steering +28
Z22 Rally Sport Package +27
Z28 Special Equip. Package +83
ZL2 Special Ducted Hood +8
JohnZ
CRG
'69 Z/28 Fathom Green
Old Feb 3rd, 06, 06:18 PM
SoCalFirstGen SoCalFirstGen is offline
Tech Team
Mike
Default Re: '69 Camaro Weights
Oooh, do you have the same for a 68???
My 68 : (0-60 in 5s, 1/4 in 13.22s) 350ci, th-350, open 2.73 8.2", 295/60 rears, QA1 12 way rear & front w/coil adjusters. In Garage: 415ci roller stroker, Tremec TKO-600, 1350 D-shaft and ...
Old Feb 3rd, 06, 10:16 PM
68rs406 68rs406 is offline
Sean
yes, do show the 68 please!
by the way, what added 83 #'s on the Z28 package? was that a sum of all parts included w/rpo Z28, or in addition to the parts/options listed above?
Sean
1968rs, formerly a 406 sbc, 354" SB2.2 coming soon...
"Aerodynamics is for people who don't know how to build engines" - Enzo Ferrari
Old Feb 3rd, 06, 10:40 PM
davidpozzi davidpozzi is offline
David Pozzi
Thanks John!
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Feb 4th, 06, 05:58 AM
clwilcox33's Avatar
clwilcox33 clwilcox33 is offline
Christropher
Sweet John! Thanks! Hopefully you can find a list for the 67 and 68s
Christropher
1967 RS/SS 350...in pieces still.
http://www.67rs-ss.net/
**How to attach images**
MrDanB - "Don't worry about Mr.Wilcox...He has that incurable disease of thinking that they only made the Camaro in '67 "
Old Feb 4th, 06, 10:49 AM
RickD RickD is offline
Wow - thanks!
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
Old Feb 4th, 06, 06:00 PM
Team Member
John
I think that includes the added weight of the mandatory power disc brakes, 12-bolt axle and multi-leaf springs, 3-row radiator and fan/clutch, dual exhaust system, Muncie 4-speed, and larger wheels and tires (all of which are additional over the weight of the base V-8 coupe).
I don't have the '67-'68 weights, but they're in the free restoration package you can get from Chevrolet at (800) 222-1020; I just have the '69 info.
JohnZ
CRG
Old Feb 4th, 06, 07:21 PM
67LSRS 67LSRS is online now
Default Re: '67 Camaro Weights
Here they are for the 67 from the same resto doc's
6-cyl. Coupe: 2910
8-cyl. Coupe: 3070
6-cyl. 'Vert: 3165
8-cyl. 'Vert: 3325
A31 Power Windows +21
A67 Folding Rear Seat +20
C48 Less Heater -24
C60 Air Conditioning +86
J50 Power Brakes +9
J52 Front Disc Brakes +33
L22 155hp L-6 Engine +10
L30 327 Cu InEngine +39
L35 396 Cu In Engine +258
L48 350 Cu In Engine +72
M13 Heavy Duty 3-Spd. Trans. W L48 +22
M20 4-Speed Trans +7
M35 Powerglide with +14
M40 3 Spd Turbo Hydra-Matic Trans +56
N10 Dual Exhaust +38
N40 Power Steering +29
T60 Heavy Duty Battery +15
U63 Radio Push Button +8
U69 Radio AM/FM Push Button +9
Z22 Rally Sport Package +17
_____________________________________________
My 67 RS Project:
LS1 carbed, Turbo 350, 12 Bolt 3.73's DSE Minitub All "In Progress"
Old Feb 4th, 06, 09:07 PM
pdq67 pdq67 is offline
Banned
Question Re: '69 Camaro Weights
Good info but I woulda thought they woulda listed a console and gage package's weight too?
pdq67
Old Feb 4th, 06, 09:25 PM
No the listing is kinda lean. But better then nothing I guess.
My 67 RS Project:
Old Feb 4th, 06, 10:22 PM
Tech Team
Mike
Thank you. This is a great starting point (67 is close enough for me) on figuring out how much the modifications I've made have altered the weight of hte car.
Old Feb 4th, 06, 10:59 PM
Sean
thanks you guy's! excellent info. i should get myself one of those info packets, didn't know they included this type of information.
Sean
Old Dec 1st, 12, 02:48 PM
67restoproj's Avatar
67restoproj 67restoproj is offline
Pat
Old thread, but interesting information...I would have thought a convertible is lighter. thanks John
69 Camaro RS/SS Garnet Red L-48
69 Camaro Project
www.bccamaroclub.com
Old Dec 1st, 12, 05:24 PM
ZLP955 ZLP955 is offline
Tim
The 'vert is heavier than the coupe/hardtop mainly because of all the extra stiffening and reinforcement that the body needs without the bracing effect of the roof. But even with all the extra bracing, the 'vert bodies lack the torsional rigidity of coupes/hardtops, which becomes far more noticeable when adding a lot more hp and torque than stock.
'69 04A VN Z/28 69-69 715 with VE3. Ex-E/MP at Lions in LA; Now a work in progress.....
Old Dec 1st, 12, 07:14 PM
BPOS BPOS is offline
Al
The cocktail shakers are about 25lbs/ea (x4) and the convert top frame is quite heavy also.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
