12 bolt rear end question - Team Camaro Tech
Old Feb 9th, 06, 06:27 PM
q2quest q2quest is offline
Default 12 bolt rear end question
I'm going to go the minitub route and was wondering if anyone knew how feasable it would be to use a 12 bolt out of a 72 Chevy pick-up. I understand I'll have to cut off all the coil spring stuff and get it completely bare and then re-weld the leaf spring perches, but I'd have to do that anyway with the leafspring relocator kit. I was also going to buy new axles and the wheel offset hasn't been determined yet. Does anyone see a problem with my logic? Those rear ends are pretty cheap. I'm assuming they are as strong as the factory Camaro 12 bolts.
Old Feb 9th, 06, 07:51 PM
Eric Kammerer Eric Kammerer is offline
Default Re: 12 bolt rear end question
Will you be narrowing the tubes and axles too, or just going with lots and lots of backspacing? I think the truck rear is 62" wide vs. the Camaro 60".
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Feb 9th, 06, 10:41 PM
Well, I hadn't thought it that far ahead. It probably should be narrowed, but then that's more expense and I should probably look elsewhere. If you were me what would you do?
Old Feb 10th, 06, 03:14 AM
Ozz1967 Ozz1967 is offline
Matt
Location: Clovis, New Mexico for now, some where else later
If you want new...strange or moser engineering. They'll custom make an axle for you, but that will run you about $2200.00 plus shipping. OR...find you a first gen 12-bolt rear end off an old Camaro. Shouldn't be that hard to find.
Old Feb 10th, 06, 10:44 PM
67ptcamaro 67ptcamaro is offline
Good luck finding the Camaro 12 bolt for less money then the new Moser.
You should decide on your wheels before thinking about rear end. Get the wheels do your mini tub and put tire/wheel combo on the floor and measure very carefuly and order your new rear.
Or, Find the rear you want and get your wheels back spacing accordingly. but first route would be much easier to fit everthing right.
Old Feb 11th, 06, 04:33 AM
DOUG G DOUG G is online now
RedЯuM
Truck 12 bolt have a smaller pinion than a car 12 bolt.
67-69 12 bolts are getting like hens teeth.(seen $1000 adds for housing only)
A wider rear will fit if you use more backspacing. (so no deep dishes)
Depending on use an 8.2" can live and if you're going to be racing an 8.5" can be built to take quite a bit.
IMO.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Feb 12th, 06, 12:02 AM
69X11 69X11 is offline
Keith
If you want a slightly narrower rear end, keep your eyes open for a rear out of a 65-67 Nova. you'll have to move the spring perches, but they are a little narrower.
Old Feb 14th, 06, 01:49 AM
Thanks everyone.
Paul
Old Feb 14th, 06, 05:47 AM
pdq67 pdq67 is offline
Banned
Thumbs up Re: 12 bolt rear end question
If you want to be different, try thinking about a MOPAR 8.75" pumpkin rearend????
There are Chevy car 12 bolts and 8.5"s, Ford 9"s and MOPAR 8.75"s.....
It's a very good rearend too that is oft overlooked...
AND I figure CHEAP enough!
You will have to redrill the axles and such, but you have to do that to a 9" anyway...
pdq67
Old Feb 14th, 06, 12:59 PM
big gear head big gear head is offline
Freddie
A Camaro with mini tubs needs about a 56 inch rear end. The truck rear end will have to be narrowed, no way around it. You can build the truck rear end with c clip axles and keep the cost down. You can also use the 9.5 14 bolt truck rear end if you want something even stronger. These use 33 spline c clip axle, and there is a very good Eaton posi available for it.
'69 RS/SS396 pro street/427/4spd/9"
http://www.camaros.net/showroom/show...00&ppuser=1922
Old Feb 14th, 06, 01:11 PM
jdogg23 jdogg23 is offline
Tech Team
jason
Ive got a question i just bought a 67 factory bb with a 12 bolt rear end. Its not posi track. Is that how they came in that year. whats it take to put in a close to factory posi in terms of cost
thanks
jason
Old Feb 14th, 06, 04:02 PM
Freddie
Posi was an option, not standard.
