Miikeremains said:
You do not need to put an extra coat on a week later in order to sand out dirt with 1500-2000. I stated to put an extra coat, a third coat, to allow for enough material to work with as far as dry spots and such. There is no advantage to having 8 coats of clear. If a paint job is wheeled out correctly you will not tell the difference between a finnish with one coat, or 10 coats. Shine is a reflection. Does a puddle of water reflect the sun stronger if is 5 inchs deep rather than 1?
And i have personally seen clear shatter. A guy brought a car to our shop that he had done by a friend in florida. The guy put alot of clear on the car. He didnt know how many coats, but he said alot. The front of the hood and bumper were all shattered. Like cracks in glass. A closer look and i realized this was caused by rocks. There were center points where u can see was an impact by pebbles. What could have been an easy fix of chips, turned into a stripping the panels.
I didn't say you had to put another coat of clear on in order to sand dirt and dust out.
I said for a show quality job, its recommended to use a flow coat. Look it up in HOK tech manual.
Sure, you can add another coat and sand 2 coats off to remove orange peel and dirt if thats what you want- I prefer to not do it that way.
PPG states that you need 1.5 mils minimum AFTER sanding and buffing to keep your warranty. 2 coats at 1.0 mil each (typical HVLP applied spray build)will not give you the required film build after sanding. 3 coats will barely get you by, and you may be in trouble if you have a lot of orange peel or dirt nibs.
There could be a lot of advantages to 8 coats of clear- depends on if you are trying to hide edges in design or art work. Not common on most cars, but I have seen it. You actually don't end up with 8 coats, because you are sanding between applications. But, you are correct, I wouldn't dump 6 coats (or 5 for that matter) one right on top of another.
As far as the clear shattering- it sounds as if they put too much hardener in, or possibly too many coats of clear without the proper wait time.
