Bug Hunt Computer related problems
Virus warnings - Technical help.
Old Feb 24th, 06, 07:13 AM
Brackneyc's Avatar
Brackneyc Brackneyc is offline
Craig
Default wireless connection/internet
I have a question for the computer guys here. I just bought a new laptop that has a wireless connection built into it (I think that is how you describe it). I do not have a wireless router at home. After school yesterday (where I found out I could log onto their system with my laptop), I tried to get a wireless connection at home. Well, I was able to log onto something, but not sure how that works. Did I connect through a neighbors system? If so, what are the potential problems with doing this? Am I breaking any kind of laws by logging onto a wireless system from my home if I do not have the equipment in my house? Any other info on this would be great. How about unsecure lines and the potential for someone to steal informaton doing it this way.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old Feb 24th, 06, 07:43 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Re: wireless connection/internet
Brack,sounds like you tapped into your neighbors system. While not necessarily illegal, if you told the neighbor, what would he say? If he wouldnt like it, then dont use that system, but if he says, 'go for it' then its like wireless at the college, its just out there but that neighbor could tap into your system if he is a guru.
A wireless modem for your home isnt expensive and will give you a stronger signal and allow you to move around the house/garage with your laptop. Id get a wireless modem and have fun on your own dime.
Click..is Jim..69RS-LM1 350/255 - 700r 4speed auto.
Our Camaro Webpage
Photos for viewing
Learn How To Post Pics here
Old Feb 24th, 06, 08:08 AM
Brackneyc's Avatar
Craig
Thats what I plan to do. I have a hard line, which I promptly connected after my little experiment. I was just curious, and also wondering if I get a modem, how does my system know to connect to mine, and not the guys next door?
Craig
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old Feb 24th, 06, 08:10 AM
HaulnSS HaulnSS is offline
John
FYI, if you do get your own wireless router, take the time to setup some encryption so that you don't share it, like your neighbor is doing. WEP encryption is very easy to setup and just takes a few minutes. Most people buy the router, hook it up and it works, so they don't change anything on it. I work on some systems near Purdue University, you wouldn't believe how many "open" wireless connections there are.
http://www.haulnss.com
Old Feb 24th, 06, 12:59 PM
KevinW KevinW is offline
Kevin
I just set my wireless router to only accept certain MAC adresses. That way I dont have to take the overhead of encryption. Plus my nearest neighbor is 500 ft away and I dont think my B will reach that far
Old Feb 24th, 06, 01:09 PM
ScottB ScottB is online now
Your system will connect to the strongest signal. Without WEP encryption you may also connect to your neighbors system if the signal is stronger. Unless you have a server connected to your system, or you don't want any neighbors to use your internet connection encryption isn't necessary.
Old Feb 24th, 06, 02:15 PM
blackvi blackvi is offline
Jerry
Exclamation Re: wireless connection/internet
Brackneyc
That sounds pretty common. The posts on this topic are right on. You tapped into your neighbors wireless network and basically have "free" internet service. It's the easiest yet most vulnerable method of installing a wireless system.
Have you ever heard of "hot-spots" Thats the equivelent of you neighbors house. Any "hot-spot" is a wireless portal for users to hit the NET without the hassle of configuring their laptops... used mostly in coffee shops.
Now with all the network security, they basically are shuting these systems down and using more evolved techniques to ride the wireless wave.
here's a very reputable router I that I personally recommend from Walmart:
http://www.walmart.com/catalog/produ...uct_id=2470125
You may also find it at Circuit City, and Best Buy.
Installing it may be diffucult (depending on your network, ISP etc) But I highly suggest getting one. Any questions, feel free to ask!
Email = blackvi2000@hotmail.com
Jerry - Systems Specialist, IT consultant, Hot Rod Enthusiast -- Searching for a way to tap into the hidden strengths that all stroked SBC’s have. Then one day, an accidental overdose of Camaros.net altered my body chemistry.
Old Feb 24th, 06, 02:33 PM
rojo rojo is offline
Robert
I was at Comp USA today and they had their brand wireless router for $9.99 after $40.00 rebate, who knows of the quality. I already have a D-Link but just noticed that price was hard to beat.
A neighbor I've yet to identify recently setup wireless and was causing me to have trouble. It took me awhile to figure it out but he was on channel 6 like me, which is the default. I switched over to channel 1 and all is now well. I also set the ID on my router to "virus", it looks somewhat intimidating seeing a connection named "virus".
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
TC member #18
Old Feb 24th, 06, 03:11 PM
Jerry
Rojo,
9 Friggin Dollars?!?!?! yup that hard to beat!
The only problem I have ever seen with less expensive routers was the firmware.
But for 9 bucks, I'd have to try that!!!!
Old Feb 24th, 06, 04:51 PM
Robert
They had the same deal on USB wireless cards. No telling how long it takes to get your rebate.
Robert
TC member #18
Old Feb 24th, 06, 05:53 PM
69mkitmine 69mkitmine is offline
Tech Team
Keith
Post Re: wireless connection/internet
While we're on the subject, my cordless phone shuts down my router everytime I answer the phone. Any quick fixes for that? Dell2350.
Keith
1969 Camaro looks good from 20ft....without your glasses!
Old Feb 24th, 06, 09:53 PM
supv26 supv26 is offline
I also had the same question. As we speak (type) I am at my wife's granny's house and my when I turned my laptop on it immediately detected a wireless connection. It connected and is VERY fast.
Question? Is this "legal" or just unethical if it is the neighbors internet. (I think it is a free service of her retirement living trailer park)
Also, if this is unsecured can someone hack my laptop? I have firewall and virus protection....
Old Feb 25th, 06, 08:10 AM
thedugan's Avatar
thedugan thedugan is online now
Team Member
Doug
Your phone is a 2.4ghz phone and the wireless router is a 2.4ghz router. Can you say conflict? The only way to fix it is to set the channel of the phone to 10 and the router to 1. The farther the two numbers are apart the less conflict you will have. The problem is most phones change the channel every time it rings so that's what causes the conflict ever once in a awhile.
I tell most users to buy 900mhz phones because wireless will confilict with just about every other phone made but the 900mhz units.
-Doug
68 RS/SS Conv
Restoration started 5/25/07.
Have it for spring 08? Motor is finally done (3/8/08)
Have it by summer 08? Nope
Have it by fall 08? Nope
Have it by Winter 08? No way
Have it by Spring 09? Nope but its made it the the body shop.....
Have it for Summer 09? Possible
Old Feb 26th, 06, 04:56 PM
Tech Team
Keith
Thanks Doug. I'll swap channels.
Keith
Old Feb 26th, 06, 07:21 PM
phel69 phel69 is online now
Bob
69mkitmine,
If you are using a DSL connection you can experience disconnects when answering incoming calls if the modular jack in the interface (EBN) on the side of your house is defective. You need a voltmeter to check it out. On the telco side of the jack you would read about -52 vdc. On the other side of the jack you would see around -22 to -28 vdc usually. This is with the phone on hook. When the line rings in it generates many crc errors in this condition and disconnects the DSL although the phone usually still works fine. If that is the issue then it is up to Telco to come out and replace the interface jack.
I use 4 seperate 2.8 gig cordless phones in my house with my 2.8 GHz wireless router with no issues at all. They can interfere with each other but are usually fairly tolerant of each other.
Bob
Garnet Red 69/SS396/TH400/355 Posi Sold
'02 triple blk Vette Vert. now
94 HD Dyna Wideglide
