Disc brake conversion info - Team Camaro Tech
Old Mar 6th, 06, 04:30 AM
Rocketrod Rocketrod is offline
Default Disc brake conversion info
Wouldn't it be great if we developed a sticky that listed a "complete, update list with: potential donor cars, master cylinder recommendations, part numbers for e-brake cable and misc pieces, brake lines, prop. valves, etc, etc" for 1st gen related disc brake conversions.
Maybe with two categories, one for stock discs, 11" discs, and the other for CBB 13"/12". I know if you dig enough most of this information can be found, but it can be very time consuming and as popular as this conversion is it would definitely be welcomed......maybe then we could do the same for 1st gen suspension upgrades and actual troubleshooting....
Rod
69 Camaro with LS2/4l70e
Smoothing firewall and Upper dash panel replacement
Old Mar 6th, 06, 09:06 PM
davidpozzi davidpozzi is offline
David Pozzi
Default Re: We need a disc brake conversion sticky.....
If people want to post links or info to this thread, I can make it a sticky thread.
If you post a link, please give a short discription of what kind of info it contains.
I have a donor list and a fiew other things I can add.
Also be sure to check the Camaros.net main page for tech tips and info. DJD posted a brake swap there.
David
4 WHEEL POWER DISC, STOCK FRONT, TORONADO REAR.
http://www.camaros.net/forums/showthread.php?t=75298
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Mar 7th, 06, 01:55 PM
David
Here is a link, http://www.camaros.net/techref/articles/ftecref012.html , to the article Dave mentioned.
Rod
Old Mar 8th, 06, 10:32 AM
MrDanB's Avatar
MrDanB MrDanB is offline
Dano
Fabulous idea! I had trouble finding in-depth info for a pdb swap last month. If it wasn't for Pozzi's page, I would have been lost! Thanks
Dano
If you can't see the bright side of life, try polishing the dull side...
Old Mar 13th, 06, 08:45 PM
If you have done any research on upgrading your 1st gen with C4 brakes you have probably come across the link below. A very well written article with covering all aspects of the swap including part numbers.
http://www.geocities.com/torkerscamaro/torker.html
Rod
Old Mar 22nd, 06, 06:34 AM
69X11SS 69X11SS is offline
I have done the WS6 conversion on my 75 Camaro. It would be the same exact install on a 68 and 69. There are several donor cars available to use. The easiest would be the 79 to 81 Trams Am WS6. All the parts are still available new or rebuilt. The only required donor part is the caliper mounting bracket. The Trams Am brakes will not work on the 67 because they do not have staggered shocks. There are several other cars (Seville, Eldorado, & Riviera (78 - 84)) that are possible donors. I remember at least one of them has the calipers both clocked to the rear so they could be used on a 67. The only problem would be the bolt pattern if you are using the rotors. Some of the Cads had a 5" bolt circle versus the 4 3/4' circle on the f-bodies. I have a list of the GM part numbers that you can use and which ones will interchange. Shoot me an e-mail if you need them.
There is a fine line between hobby and obsession!
69 SS, 350, 4 Speed
69 350/350 4 Speed Corvette Convertible
Our Cars Click on my Cardomain user name to view both cars.
Old Mar 22nd, 06, 07:43 AM
sixtsevnssrs sixtsevnssrs is offline
Tim
Thumbs up Re: We need a disc brake conversion sticky.....
69X11SS,
Check out my budget brake conversion in my signature. Some of your info is not exactly right.
Old Mar 23rd, 06, 06:06 AM
Which part of my post do you find incorrect? The only thing that I gave absolute information about is the fact that the T/A setup would not bolt on to the 67. I did not mention modifying the brackets. There are a lot of different rear disc setups that can be made to work. The 79 - 81 T/A is the only direct bolt on application. The 76 - 79 Eldorados & Devilles and the 77 - 79 Sevilles have a 5 inch bolt circle. The 81 - 84 have a 4 3/4 bolt circle. The earlier Caddy's also had the 11 inch rotor versus the smaller ones on the later models.
69 SS, 350, 4 Speed
Old Mar 23rd, 06, 08:28 AM
dawg's Avatar
dawg dawg is offline
Harry
yes good idea for a seperate room for this.
aswell as any other major upgrades like manual to power steering etc.
coil over shocks conversion .
Dawgs 69
406 stroker
us navy retired
http://www.northeastf-bodyassn.com/
Old Mar 23rd, 06, 10:29 PM
Tim
Cool Re: We need a disc brake conversion sticky.....
I wasn't trying to cut you up 69X11SS. Your years were a little off is all. Inclusive donor cars are the 79-85 Eldorado, 80-85 Seville, 79-85 Toronado and Riviera all with 10 1/2 diameters with a 5 on 4 3/4 bolt patterns. Parts are all the same according to Raybestos part numbers. This is the conversion I used. The donor cars are all rear mounted calipers. You can overcome this for the 68-9 or maybe later by using two right side calipers and in staggered positions.
I also have rear calipers and brackets from a 77 Fleetwood. I was originally going to use these for my Camaro but started looking at the brake bias in regards to the front calipers. They are huge and yes the rotor is 5 on 5. The rear rotor from the WS6 TA is exactly the same except a 5 on 4 3/4 bolt pattern, but I don't think the caliper is as big. I wonder if the 78 Eldorado/79 Seville and earlier and the Fleetwood are the same or if maybe they are the same as the WS6?
I don't have any of my Raybestos books here right now to look, else I would. What was the first year for the Seville/Eldorado rear disk brake option? What years are inclusive to the Fleetwood rear setup? I think you could just about get anything to work, just have to make/modify the right brackets and use an adjustable proportioning valve to increase and decrease pedal pressure to the rears.
I don't know how much better the newer brakes systems such as the C4/C5 corvette conversions or the 1LE and other 4th Gen Camaro conversions are when compared to my conversion but I am pretty sure that I couldn’t stop any quicker unless I upgraded my suspension and tires. You have to tune your brakes to your tires. Tires are what will limit an upgraded brake system. Once you hit the threshold to skid, more brake is not going to help you.
What are your thoughts?
Old Apr 22nd, 06, 10:00 AM
DOUG G DOUG G is offline
RedЯuM
I haven't read everything yet... but will these rear disc set-ups fit 15" wheels ?
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Apr 24th, 06, 12:49 PM
Tim
Post Re: We need a disc brake conversion sticky.....
The setup I describe fit perfect.
Old Jun 23rd, 06, 06:14 PM
Raw Raw is offline
you seem to no what you are talking about i whant to ax my drums and convert over to disc brakes but im on a really tight budget i have a 67 camaro..what years would enterchange with my 1967 camaro....i dont have a problem hunting junk yards for parts....thank you 4 your time...you allso could email me the info ronribalai@comcast.net
Old Jun 26th, 06, 10:17 PM
Tim
Default Re: Disc brake conversion info
Raw,
Check out David Pozzi's site. Check out my links and do a search for the same topic. There is a lot of information and doing a lot of research goes a long way.
Here is the link to Pozzi's site, he lists most of the donor cars here, and is an excellent source of info on swapping.
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
Old Jun 27th, 06, 10:26 PM
j69camaro j69camaro is offline
Exclamation Re: Disc brake conversion info
I read somewhere that 98-02 Camaro brakes work on a first gen with little trouble. I did a little research and it is true. I have 98 camaro brakes on my 69 all the way around and it only cost me $300. Believe me it stops on a dime, looks great and I didn't have to buy Bear brakes which I couldn't afford anyway. E-mail me at J69Camaro@aol.com and I can send pics.
Similar Threads
69 camaro disc brake conversion kits Lance Brakes, Suspension & Steering 9 May 30th, 06 05:01 PM
14" wheels and disc brake conversion? 68driver57 Wheels & Tires 5 Feb 8th, 06 05:18 PM
Disc Brake Conversion Kit, Muscle Mad Brakes, Suspension & Steering 15 Dec 11th, 05 09:07 PM
Disc Brake Conversion foooz Brakes, Suspension & Steering 7 Nov 15th, 05 03:13 PM
