| Team Camaro Tech Current Topic: 67 Brake Rotors | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
Does anyone know where I can get a set of brake rotors that will fit my '67? It has a set of the original 2 piece rotors now, and I want to replace them before they are completely shot. I know Ricks and Firewheel have them for around $110 each. Also - are the pads something any auto parts store will have - or are they a weird size/shape?
Thank you!
'67 RS/SS Black on Black 350 4-Speed |
| Sponsored Links | ||
Advertisement | ||
Good point!
Does anyone know where I can get rotors for less than $110 each? And - are the pads something I can get at Autozone or Pep Boys - or are they some weird size that I'll only find at Ricks or Firewheel?
Check RockAuto, they had brand new Raybestos rotors for $38/each, or Raybestos Brute Stop Rotors for $100/ea (cross drilled)
54.20 each if you can use a one piece.
http://www.discbrakesrus.com/make/chevrolet/camaro.htm
ERIC 67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi |
you can get them thru any autoparts store for much less than $110 per. They are all 1 peice now. parts store can get the pads too. probably not in stock, but never long to wait either.
JimM's firstgens.com Camaro Board Jimragtop.com New website for my vert is coming together. Do ya like the slide show on the home page? |
Thanks guys! I will check those sites out. The problem I keep running into when places offer '67-'69 rotors is that they don't fit my setup. I think the '68 and '69 have a different caliper than the '67.
67 and 68 use four piston calipers. The four piston calipers need a smaller hub area in the one piece rotor for caliper clearance.
69 uses single piston calipers.
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com 67 RS 327 original owner. 1965 Lola T-70 |
Parts stores should be able to get the D3 pads.
I haven't been able to find the small hub rotors inexpensively anywhere. Every time i think i do, they turn out to be the 69 large hub style, which is the only one the local parts stores carry. Bendix, Raybestos, Wagner, and their knock-offs all have the large hub.
If I didn't learn it from my my mentors, I learned it as a result. my car pleasurizer.com |
OK - So I bit the bullet and bought a set of rotors from Rick's for a couple hundred bucks. I have the wheels off, and the caliper off the driver's side. Now - how the heck do I get the old rotor off?
| Sponsored Links | |
Advertisement | |
