mounting windshield washer nozzles - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Mar 19th, 06, 01:20 PM
bl1work bl1work is offline
bl
Default mounting windshield washer nozzles
i'm trying to figure out what part i'm missing... i'm putting my 69 back together, and i'm attaching the windshield wiper nozzles... question is how do these guys bolt down? The manual just shows a screw holding them down, but on my car there is a 3/8 or so dia hole where the screw needs to go. Is there supposed to be some kind of clip or something that goes in the hole that the nozzle screws into? I can't find any pics, parts etc, other than the screw. thanks for any help,
bl
Old Mar 19th, 06, 01:29 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Re: mounting windshield washer nozzles
The nozzels have an elbow with a threaded shank that is adjacent to the nozzle end, the elbow with the hose burrs go up thru the panel and some of the threads show too, then a nut screws down onto the nozzle threads from on top of the grille piece and pulls the nozzle flush to the grille area facing the headlights. Does that make sense? hope so, going by memory here. Its a very flat nut too and a chrome washer goes over the elbow first.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Old Mar 19th, 06, 01:33 PM
KevinW's Avatar
KevinW KevinW is offline
Kevin
Ah, Jim, I think he is talking about the regular nozzles on the cowl, not the grill ones. The nozzles on the grill have a flat bar sticking out the side with a screw hole . The bar goes into the square hole and a small hex head screw holds them to the Vent panel (not cowl!). sorry
Old Mar 19th, 06, 02:25 PM
click's Avatar
Moderator .. Jim
Jim
Ooops yep Kevin you are right. There is a tab that goes in the larger hole you see, and a very small tiny sheet metal screw with hex head that secures that metal tab in place. Should be 2 holes, one larger and one tiny. forget the previous for RS headlight washer nozzels
Old Mar 19th, 06, 02:39 PM
JimM JimM is offline
Jim
you guys are confusing me....
This had me going on my 68, too, cause I wanted to put the nozzles on before I put the cowl vent on!
The screws that hold the nozzles on thread into the vent panel, not the cowl itself. The square holes in the cowl are where the nozzle screwholes in the vent panel are when you drop the vent panel on.
Old Mar 19th, 06, 03:15 PM
click's Avatar
Moderator .. Jim
Jim
I went out and looked at mine just now, I confused my self. The long nozzle sticks down thru the square hole and then turns up to aim thru the cowl vents. the small tab with the hex screw is on the horizontal lip below the cowl itself, not sure I made more sense but thats what I saw
Old Mar 19th, 06, 03:40 PM
KevinW's Avatar
Kevin
Then mine must have been installed wrong, cause they were on the vent panel. When I put it back together, I will hit the aim and make sure.
Old Mar 19th, 06, 05:21 PM
bl
haha... now i'm really confused, i'm going to provide a pic of what i'm looking at on mine so maybe i can understand better... hope this works
Old Mar 19th, 06, 05:23 PM
bl
oops sorry about the size
Old Mar 19th, 06, 05:34 PM
69CamaroRT 69CamaroRT is offline
Bobby
do you have an email address, if you like, ill send you a pic of how it installs. pm me if you want.
69 Camaro Z/28 Rally Sport 10A of 68. 50 S with 723 int. .040 over 302 with m22 autogear wide ratio. BU 12 bolt posi. http://s190.photobucket.com/albums/z...view=slideshow
  #11
Jim
exactly the same as my 68. The nozzle attaches TO THE VENT PANEL. when the vent panel is installed, the nozzle will lay in the groove, and the screw will drop thru the large hole in the cowl.
  #12
Old Mar 19th, 06, 05:46 PM
bl
I thought that it might attach to the vent panel, but that is one of my parts that is still at the body shop in primer. guess i won't be installing these guys yet.
  #13
Old Mar 19th, 06, 05:53 PM
Bobby
bl1work, you have mail. hope this helps.
  #14
Old Mar 19th, 06, 08:34 PM
click's Avatar
Moderator .. Jim
Jim
My hood is covered now and not easy to get too. The squirter lays in the groove as mentioned and the little tab goes up thru the cowl panel and lays on top of the cowl where its secured with the tiny hex head screw.
I unwrapped my car and took this pic today, hope this helps.
  #15
Old Mar 20th, 06, 12:11 PM
click's Avatar
Moderator .. Jim
Jim
back to the top
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: mounting windshield washer nozzles
Location
Location
First Name
Human Verification
