Quick Help on i/d top & 2nd Summit cast chevy .030 rings - lost box - Team Camaro Tech
Old Mar 20th, 06, 08:54 AM
caribbean camaro caribbean camaro is offline
Question Quick Help on i/d top & 2nd Summit cast chevy .030 rings - lost box
As message says - the box got wet and I lost markings
Which ring is likely to be top ring?? - in a set where one is marked with a dot and has a beveled inner side and the other is not marked by any dot and seems square all around
T.K.-85 Camaro-383ci/AFR 210 CNCport-65cc/ProSystem750DP/SRP 7cc dome/Motown int./Comp.S roller 268/275-108*-.720"/.700"@1.6/Big Shot plate/TH-350/8in. conv./4.71 Ford 9in/1.75 super comp/10pt. cage/29.5x10.5x15
Last edited by caribbean camaro; Mar 20th, 06 at 08:57 AM. Reason: did not finish ?
Old Mar 20th, 06, 09:44 AM
camcojb camcojb is offline
Jody
Default Re: Quick Help on i/d top & 2nd Summit cast chevy .030 rings - lost box
I'm not a guessing guy, but if I had to I'd say the beveled ring with the dot is the top one, and the plain unmarked one is the second ring.
I would call Summit to see if they can open another box or give you the manufacturer contact for those rings. You do NOT want to get this wrong.
Jody
Jody
My New Car Site
Lateral-G.net
next project.... 73 Camaro RS street/road race car
Old Mar 20th, 06, 09:58 AM
1962vette 1962vette is offline
Paul
Top ring white dot up (bevel to top of piston), second ring can go either way. Not guessing.
Old Mar 20th, 06, 01:12 PM
"Top ring white dot up (bevel to top of piston), second ring can go either way. Not guessing."
I take this to mean that if one of the ring sets does not have a dot that its a "second" ring that can be installed "either way"
Please confirm
