| Team Camaro Tech Current Topic: Muncie shift handle on Hurst shifter? | ||
Does anyone know if a Muncie shift handle will mate up to a Hurst CompPlus shifter? I saw something on the Chevelle site, but it was for the round Muncie shift handle. I'm wondering if it can be done on a 68 with the flat handle.
Kevin
Kevin 68 Butternut Yellow RS 327 4spd Convertible Loose trim tag database 88 IROC low budget project |
| Sponsored Links | ||
Advertisement | ||
I'd like to know also. Just in case I ever find one that doesn't cost as much as the tranny itself. Mike
68 SS350 4spd. http://s185.photobucket.com/albums/x223/laurens68/ |
yep
The Hurst handle mounts with two bolts while the Muncie mounts with a pin arrangement in a carrier so is much longer. Cut the Muncie handle off with your favorite cut-off tool and drill and mount to the Hurst. Might require some fitting as handle appears a bit wider..friend of a friend did it. The Muncie is permanantly neutered after this surgery unless you find a new handle! |
I did this swap a few years ago. Instead of screwing up a good Muncie handle I picked up a used one (actually from a 3 speed) and cut it off as per the previous post. Before you make the cut, take the Hurst handle and lay it up against the Muncie handle. This will give you an idea where you will then make your cut. The curve of the Hurst handle and the Muncie were very similar in my case. Once cut drill the 2 mounting holes and you're in business.
1966 L72 2 door post Biscayne bench seat M21 4.10, 16K miles 1968 Z28 RS cowl plenum M21 3.73, fresh 302MO stored 450hp 355/Tremec TKO 1970 SS350 Nova daily driver bench seat M21 replaced with a Tremec TKO 1949 Meteor Pro Street 468/4L80E 1955 Chevy Gasser BBC M22 410's |
| Sponsored Links | |
Advertisement | |
