| Team Camaro Tech Current Topic: big hole truck bell housing | ||
I keep discovering odd things while dismantling! I find out the bell housing in my 69 b/b - M20 4sp is a "big hole" truck bell. Is this going to be a problem - I think I read in other posts that the allignment could be off - any help is appreciated.
| Sponsored Links | ||
Advertisement | ||
It will cause some serious problems. I understand that someone is making a spacer ring but I don't know who.
This IS a big problem, the trans is centered on the crank centreline by the front bearing retainer fitting into the bellhousing hole snugly.
The truck bellhousing has a bigger hole and the only thing holding the trans in posistion is the bolts, allowing it to be off centre. This will kill the 4th gear syncro and also be hard on the input bearing. You could make a thin ring to adapt the trans retainer to the bellhousing hole or find the correct bellhousing. 621 bellhousings are now being reproduced. Hope this helps. Mike.
1994 Lumina Z34, 2655lbs. 446" Small Block, Brodix Canted Valve, lenco 5 speed, 8.21/167 Best. New Bickle Cavalier, 1810lbs for 2010. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973. |
thanks guys - I guess the best is to find a used "proper" bell. This site has helped me a great deal! Glad I found out now instead of wrecking my tranny.
Do a search for this under my name b/c I have posted the info on the guy that makes it and sells it for a decently CHEAP price vs probably buying a different B/H.
pdq67 |
I know a guy in Atlanta,GA that has some if you need a good bellhousing for your BB 67-69 Camaro.
"There are two ways to do this... My way and the Wrong way." - Dale Earnhardt '99 Neil http://www.chevymania.com/partsid http://www.mortec.com |
Well, who is he??
pdq67 |
well guys, I'm confused. I think I prefer to go with the proper bellhousing for the b/b. Am I limited to the 621 bell if I run a 10.5" clutch, or are there different bell numbers I can look for to fit my application??
I had "thought" all BB's used the 11" clutch...but if you have a 10.5" setup noe and your block is drilled for that starter, you can keep it.
Do some searching on bellhousing part numbers here, it's all in the archives. When I had to change mine this winter, I found a post by vintage68 that listed some part #'s, and I found a compatible nova bellhousing on ebay for WAY less than Camaro bell's bring.
JimM's firstgens.com Camaro Board Jimragtop.com New website for my vert is coming together. Do ya like the slide show on the home page? |
ADVANCED ADAPTERS is one company who sells the adapter I have on in front of my Muncie.
#11
thanks guys, I'll do some thinking.
#12
This should help: http://www.teufert.net/other/chevy_s...sing_guide.htm
#13
As for the starter issue,, can't you just change starter drive noses? Thats what I did when I went to large housing and flywheel . If you are not numbers person,, go to a GOOD mini starter. I used a Tilton on one of my cars.
Don TC # 349 Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E http://s102.photobucket.com/albums/m...t=115_1577.jpg |
#14
well guys, I ordered the adapter from Advance Adapters today ($34.00) to put into my truck bell. Bought a new 11" clutch & pressure plate, and seeing as the starter cross references to a 1963 327cu.in - I'm buying a new stock starter tomorrow....what the hell, it's only money (Canadian money at that!). I hope that will complete my switch to the bigger clutch assembly?
| Sponsored Links | |
Advertisement | |
