3925660 Muncie - Team Camaro Tech
Thread Tools Display Modes
Old Mar 24th, 06, 07:56 AM
Jamie Shytle Jamie Shytle is offline
Tech Team
Jamie
Wink 3925660 Muncie
I just purchased a Muncie that is supposed to be an M-21.
The numbers are as follows:
3925660
Also: P9T0A
The tail piece has 3884085 casted into it.
The front shaft has the single groove with thick splines.
Can anyone identify"
Old Mar 24th, 06, 09:56 AM
1962vette 1962vette is offline
Paul
Default Re: 3925660 Muncie
Trans was originally an M-20 as verified by P9ToA THe last letter, A =M-20 , B=M-21, C= M-22.That being said ,the single ring on the input shaft is the identifier for an M-21, two rings M-21, no rings M-22 or replacement input that had no identifier rings.
This trans appears to have been rebuilt at one time using close box parts.
JodysTransmissions JodysTransmissions is offline
Originally Posted by Jamie Shytle
ShyThe front shaft has the single groove with thick splines.
1 ring = M21
2 rings = M20
Jody Haag
JodysTransmissions@verizon.net
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
Jody's Transmission Facebook Page
Autogear Muncie Distributor
Legend700 5 Speed Distributor
Old Mar 24th, 06, 10:09 AM
Tech Team
Jamie
Talking Re: 3925660 Muncie
Thanks for the info
I knew it was just rebuilt. Will the Hurst comp+ shifter and linkage work with the M-20 case. I hope there isn't any difference. This whole thing is turning into a lot more than planned.
But, I'm not grumbling!!!!!! ain't nothing like shaking hands with 500+hp
Old Mar 24th, 06, 11:34 AM
Paul
No difference in Hurst shifter. Just be sure you have the correct shifter as far as the style shifter arms that are to be bolted to transmission. Early trans (63-67)have a stud with attaching nuts and later trans (68-up use a bolt to hold arms on.These arms are not interchangable
Old Mar 24th, 06, 05:29 PM
crashent crashent is online now
1968 Model year and older use studs to attach shift levers...
1969 Model year and newer use bolts to attach shift levers...
Hope this helps... Crash
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: 3925660 Muncie
Location
Location
First Name
Human Verification
