| Team Camaro Tech Current Topic: Right Cowl Airflow Question | ||
| Body Shop Paint & Body Forum |
Another question for those in the know.
While prepping the passenger side for the inner and outer rocker replacement, we found some rusted away vertical inner partitions (seen from inside the car)that reside behind the iner rocker. We've fabbed some repair metal, but I don't know how it was originally. This is an A/C car. Is the fan inlet area of the cowl, as it drops down, open to the rockers like the driver side? If so, the fan would be drawing air from the rocker except for the rubber flapper at the rocker rear. If you lose that flapper, it would seem you'd be drawing air/water/snow in. As always, any help is greatly appreciated.
Joe & Jeff "Project Rusty" (1969 X-44 Camaro Coupe) '68 Factory RS 327 Camaro |
| Sponsored Links | ||
Advertisement | ||
Those are just rocker reinforsement pices, the air flows the other direction from the cowl through the rockers and out the flap in the rear.
____________________________________________ So then the passenger side forward rocker area is an exact mirror image of the driver side?
Yes.. I have replaced both my outer rockers, repaired both inner rockers and fabed up the pices you are refuring to.
MJM,
Thanks for the timely replies. It's off to the garage for some more weekend fun. Joe
| Sponsored Links | |
Advertisement | |
