Slight delay when turn key - Team Camaro Tech
Thread Tools Display Modes
Old Apr 16th, 06, 06:18 PM
69rag327 69rag327 is offline
Default Slight delay when turn key
Recently when I go to start car, I have noticed a very slight delay for the starter to kick in when I turn the key to engage. Nothing huge but it feels weird. You turn key and expect starter to kick in instantaneously, but there is about 1-2 second lag, like it has to think about it.
My starter is almost new (Powermaster mini starter) as is the battery. Could the solonoid be pooched already? Or could it be in the ignition switch somewhere? I had a shorting problem a little while ago when the positive battery feed was shorting on the starter chassis, could that have fried things? Once it starts cranking there is no problem, but worried one day it will decide no too crank.
Your input is appreciated.
Old Apr 16th, 06, 11:35 PM
Riccbhard Riccbhard is offline
Default Re: Slight delay when turn key
I'm not too sure on the subject of starters, but my guess is maybe the motor is getting hung up on something?
Old Apr 17th, 06, 05:33 AM
Everett#2390's Avatar
<Jake-68's rule
Try a newer battery. When max load happens on a battery, the chemical reaction heats up the electrolyte and the plates become damaged and some electrolyte evaporates.
Now with a lower level of electrolye, the battery has less capacity, less chemical action to produce electricity. Damaged plates take awhile to build up (chemical action) to produce electrical current.
You could further troubleshoot and use an assistant and a clamp-on ammeter on the battery cable and view the current flowing to the starter. It should be almost instantaneous and the DVM across the battery posts at the same time, should not fall below 9.5 volts.
If the battery shows a good current flow and voltage holds up, then starter would be suspect.
Old Apr 17th, 06, 06:13 AM
dawg's Avatar
dawg dawg is offline
Harry
i had same problem and found the starter wires were melted a bit from touching the header.
rerouted wires and put insulating tape on em.
problem went away!
it made it seem like when you release the key from start the starter starts turning.
Dawgs 69
434 stroker
US Navy retired
http://www.northeastf-bodyassn.com/
Old Apr 17th, 06, 06:49 PM
Thanks for the replies. The battery is only 3 months old. Maybe too new? But I had the problem towards the end of last season and figured it was just the battery and hoped it would go away. It didn't. Maybe I will replace positive battery cable altogether. Otherwise, solonoid on 6 month old starter??? Is it possible to replace/rebuild the powermaster solonoids? Something a backyarder can do?
Old May 8th, 06, 08:01 PM
Okay, so I replaced the positive cable, made sure all connections are tight, battery is good. Still same problem, and seems to be getting worse. The 6 month old powermaster mini starter just doesn't do anything sometimes. I turn key and NOTHING, no click, no nothing. Try it a few times and suddenly full crank. So could it be solonoid? Could it be the ignition (key) switch? I am about to order new solonoid. Thought I would throw it out one last time. Thx in advance.
Old May 8th, 06, 09:33 PM
Brackneyc's Avatar
Brackneyc Brackneyc is offline
Craig
My guess is the key switch. Have you tried a push button starter (like when you would use it to turn the motor over when tuning it by yourself.)
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Old May 8th, 06, 10:35 PM
Camaro Dave Camaro Dave is offline
Try bumping the solenoid with a screwdriver. If it starts with no hesitation, you might want to look at the Ignition switch and all the wiring in between.
67 RS Camaro 327/ 350 Holley 650cfm > Edelbrock Performer Intake > Pertronix Ignition > Accel Super Stock Coil and Wires > Hedman Hedders > Hotchkis Performance Springs > 15" Rallys all around
Camaro buds until the end!!!
Old May 9th, 06, 04:52 AM
undee72Z undee72Z is offline
Heres all the wiring in between......
To check the entire starter circuit, electricity flows from the battery to the junction block, to the 4 way splice, to the horn relay, to the bulkhead connector, to IGN switch, to neutral safety switch if automatic or clutch switch if stick shift, to the starter "S" terminal. Check all connections and switches along this path. You may have a bad connection or high resistance in a switch.
Greg U
My 72 Z
Undees 70 SS, street driven drag car
Old May 9th, 06, 05:13 PM
130fe 130fe is offline
Chris
Post Re: Slight delay when turn key
I recently had this same problem with mine. It wouldn't do it all of the time, only about 2 or 3 times a month (enough to aggravate you especially during a show/cruise). If I used a screwdriver and jumped the soleniod, it would start up right away. After replacing the ignition switch, nuetral safety switch, and new wiring from firewall to starter solenoid. After each component change it would work fine for a few tries then do it again. I thought about replacing the battery cables but decided to replace the battery (4 years old). I put a new Optima red top in and no problems yet (6 months later). I would recommend changing the battery first and then change the cables (if they are old). Hope this helps!
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
  #11
Old May 9th, 06, 07:33 PM
Wow. Okay. The battery is only 4 months old. The wiring under the hood is all new from firewall on. The car is an auto converted to stick. The connections in console seem good, but I will check them again. I am meaning to change the ignition switch (key) because key is paper thin and worn. Maybe I should just do this first anyway. I am also going to take that negative disconnect thing off the battery terminal. Here's the latest clue... this morning it was quite cold up here and I barely got the thing started; it seems to be worse when cold??? I had to turn key 10-15 times until it kicked in!
  #12
Old May 10th, 06, 12:44 AM
Does the battery have enough CCA's (Cold cranking amps)? If it is worse when it is cold, then you might want to get a bigger battery with around 800 CCA's. Try that first and see if that helps your problem.
  #13
Old May 10th, 06, 07:28 PM
Fast Jack Fast Jack is offline
Jack
I had this same problem on a Chevy work truck I have. It turned out to be a loose main cable connection to the starter. It looked tight but when I got under to get a good look it would pretty easy to move by hand. I put a wrench to it and all fixed. So I think you should look at all of your connections.
Jack
67 Camaro Street car 3300 lbs
Flat Top 406 70cc Edelbrock RPM Heads
Q-jet comp xe268s 2500 stall converter
T-350 12 Bolt Posi 373's Cal-Tracs
60' 1.69
330' 4.950
660' 7.54@92.44
1320' 11.80@114.98
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: Slight delay when turn key
Location
Location
First Name
Human Verification
Similar Threads
Engine doesn't start but fires when turn key off CraigO Engine 13 Feb 8th, 06 07:29 PM
Help! Can't turn engine key! jofoleong Troubleshooting 2 Dec 14th, 05 01:15 PM
84 z28 key wont turn to on position even with new lock cylinder any ideas? 84 camero Brakes, Suspension & Steering 0 Aug 15th, 05 07:26 PM
Turn Key Off,Car still runs Flynn69 Electrical & Wiring 7 Jul 30th, 05 09:43 AM
Does "brake" idiot light come on when you turn the key?? dschribs Engine 2 May 22nd, 05 10:02 PM
