| Team Camaro Tech Current Topic: Gear shop in San Jose | ||
Can anyone recommend a gear shop in the San Francisco Bay area? Preferably one that you have actually used and had a good experience with. I am finally thinking about biting the bullet and dropping down from 4:10 to 3:23. I have never had the differential cover off of the car, but I suspect I will find a 4 series carrier, is that going to present a problem or cost me a bunch of cash to replace it with a 3 series?
Scott. |
| Sponsored Links | ||
Advertisement | ||
Scott, If memory serves me, there is a good place in Milpitas on main st. Take 237 into Milpitas, take the main st exit by the liquor barn and turn right onto main. It's about 1/4 mile down on the left. I had them rebuild an old 69 HO 327 for my jeep there. Was a complete machine shop last I recall.
Scott - check out Rearend Specialities, I've had them change a R&P, weld new spring perches and replace bearings. The only thing they did I didn't like is use gasket sealer instead of a gasket when they put the cover back on. I know others from CLNC have used them as well. Talk to Mike at 408 988-3619 they are by the SJ airport on DiGiulio...
I had good luck many years ago with "Pete's Gearshop" in Hayward on Foothill. Nice guy, Aussie I beleive. He knew his stuff.
Good luck.
Steve 1968 Coupe., filled with cool stuff from Tremec, Moser, Ron Davis, Speedtech, ATS, Hotchkis, Forgeline... blah blah blah Check it Out Here |
Speed Merchant on Lincoln Ave. in San Jose might be able to help you out too...they're a speed shop with a full service garage attached.
I used to buy all my parts from them when I lived in San Jose.
Meanchicken 68 SS ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar 87 Buick Grand National (does 10's) |
| Sponsored Links | |
Advertisement | |
Similar Threads
| New Cardone box problem? | FastFred | Brakes, Suspension & Steering | 4 | Jul 22nd, 08 01:52 PM |
| Paint Prison | KRhat | Bench Racing | 9 | Sep 24th, 06 09:31 AM |
| Rusting trunk floor and body shops in Bay Area | 67 Camaro RS | Body Shop | 10 | Jun 25th, 03 03:00 PM |
| Speedometer Gear | sschuell | Engine | 6 | May 17th, 02 08:27 AM |
| Speedo gear question. | 68SS350 | Engine | 10 | Jun 22nd, 01 12:30 AM |
