steering column bearing?? - Team Camaro Tech
Old Apr 21st, 06, 09:19 PM
67-CAM-RIDER's Avatar
67-CAM-RIDER 67-CAM-RIDER is offline
jason
Red face steering column bearing??
anyone know where i can get a lower steering column bearing for a 67??
also does anyone know the torque of the bolts for the steering coupler (power steering)
thanks in advance
Old Apr 22nd, 06, 08:48 AM
JIML82 JIML82 is offline
Default Re: steering column bearing??
The steering coupling cross bolt is 30 ft-lbs.
The two nuts that hold the flex coupling to the column flange - 18 ft-lbs.
Try looking on eBay for the lower column bearing.
JIML82
Old Apr 22nd, 06, 10:32 AM
jason
thanks
i'll look around ebay
Old Apr 22nd, 06, 10:45 AM
ohcscott ohcscott is offline
I used a lower bearing for a 69 in my 68. The outer race is a little large for the plastic adapter, but it can be made to fit. I honed the plastic and filed the metal until the 2 parts slipped together.
That was under advice i got here and elsewhere, including from "columnsgalore.com" when i called them for the correct one (which they can't get).
I picked up the 69 bearing at the GM dealer.
If I didn't learn it from my my mentors, I learned it as a result.
my car
pleasurizer.com
Old Apr 22nd, 06, 01:33 PM
400bird 400bird is offline
so what about the upper bearing? anyone know where to get that?
Old Apr 22nd, 06, 02:06 PM
Gary L's Avatar
Gary L Gary L is offline
"Tri-Tip"
Call Terry Sorvik in Oregon. Columns are what he does.
503-760-4593
"Government is not reason; it is not eloquent; it is force. Like fire, it is a dangerous servant and a fearful master." ..... George Washington
Gary,TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
Old Apr 23rd, 06, 09:25 PM
thanks, ill give him a call
Similar Threads
Steering Column Rebuild - Parts List Brian Lewis Brakes, Suspension & Steering 2 Jul 12th, 12 02:45 AM
Steering Column Upper Bearing Removal? Brian Lewis Brakes, Suspension & Steering 9 Jan 10th, 06 02:43 PM
Where to find lower steering column bearing? 40Coupe Brakes, Suspension & Steering 3 Aug 19th, 04 07:24 PM
68 Steering Column lower bearing rattec Brakes, Suspension & Steering 5 Jul 2nd, 04 03:14 PM
steering column blues- lower cup bearing camarobird Brakes, Suspension & Steering 13 Nov 7th, 03 02:32 PM
