9 inch? - Team Camaro Tech
Old May 1st, 06, 09:14 PM
PDW HOTRODS PDW HOTRODS is offline
Patrick
Default 9 inch?
I have a 9 inch that is to wide to use in anythig good. It is a 1970
rear with 31 spline axles, without taper. I know I can have the axles
cut and re-splined, but how hard is it to shorten the housing?
Can I do this at home?
Old May 1st, 06, 10:10 PM
camaroman7d camaroman7d is offline
Royce
Default Re: 9 inch?
You can shorten the housing at home IF you have a jig. As far as the axels go I wouldn't re-spline them I would just buy a new set, they are not all that expensive and the aftermarket axles are stronger.
I would not try to shorten the housing without a jig, you will end up ruining the housing (warpage) and not getting your bearing end on where they need to be and square, this will lead to wearing out bearings all the time.
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
http://www.youtube.com/watch?v=DSLsGgDjFXE
(brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers)
Old May 2nd, 06, 06:31 PM
big gear head big gear head is offline
Freddie
Default Re: 9 inch?
If the ends are not installed in line with the differential bearing bore it will also wear the splines off of the axles and ruin the differential. I have seen this before.
The axles that you have won't have the correct bolt pattern for the wheels. They will have to be redrilled, which might not be possible because Ford axles have 3 large holes between the wheel studs.
'69 RS/SS396 pro street/427/4spd/9"
http://www.camaros.net/showroom/show...00&ppuser=1922
Old May 2nd, 06, 06:57 PM
Patrick
Default Re: 9 inch?
I was thinking of using this for a 53 Chevy Pu that I am building. I have
wheels with ford and Chevy bolt pattern. I can change axles for Chevy
pattern if they can't be redrilled. I was wondering where to shorten.
Do the axle tubes slide into the center? Should they be cut at the
end, and re install the end? I have done quite a bit of frame work,
sub-framing, and shortening drive lines. But never narrowing a rear.
Just want to get the how to, or not to, befor / if / I try.
Old May 2nd, 06, 07:47 PM
Freddie
Default Re: 9 inch?
Housings are cut at the ends. The Ford ends need to be cut about 2 1/2 to 3 inches from the flange so that the seal area is not cut off. A fixture must be used to align everything.
Similar Threads
16 inch combo help please... anyone running 16x8? Eric Kammerer Wheels & Tires 5 Jun 18th, 05 09:48 PM
sizes from Chevy High Performance article michaelm5 Wheels & Tires 10 Jan 16th, 03 02:53 PM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
10 bolt vs 12 bolt vs 9 inch question cdouglass Performance 5 Aug 7th, 00 06:56 AM
3 inch or 2 1/2 inch exaust system, HELP!!?? Procharged69 Tech 2000 22 Jun 5th, 00 04:22 AM
