Intermitten horn - Team Camaro Tech
Old May 7th, 06, 04:53 PM
joemac8 joemac8 is offline
Tech Team
Joe
Default Intermitten horn
The horn in my 67 only blows when you hit the button a certain way. If you push the horn button on the side or bottom it doesn't blow. I assume that there is a contact somewhere in the button that can be fixed or replaced?
Joe
Old May 7th, 06, 10:56 PM
Camaro Dave Camaro Dave is offline
Default Re: Intermitten horn
Joe, pop the horn cap off and look at the horn ring under the cap. It might be dirty or bent. Test the horn wire to ground and see if it works 100% of the time. If it does....you know the problem is with the cap.
67 RS Camaro 327/ 350 Holley 650cfm > Edelbrock Performer Intake > Pertronix Ignition > Accel Super Stock Coil and Wires > Hedman Hedders > Hotchkis Performance Springs > 15" Rallys all around
Camaro buds until the end!!!
Old May 12th, 06, 01:34 PM
Tech Team
Joe
Dave, is the horn ground wire located near the horn or somewhere else?
Joe
Old May 12th, 06, 09:43 PM
Joe, the horn wire is actually a contact that comes up through the turn signal cancel cam and is spring loaded so that it makes contact with the ring in the steering wheel. Just get a jumper wire ( a small piece of any gauge wire) and put one end on the contact and the other side to the steering column for a ground source....the horn should sound, if the problem is the horn button.
Old May 12th, 06, 10:42 PM
Steptoe Steptoe is offline
Steps
The spring that Dave refers to gets weak...give it a streech untill u get a new one
Also check the buttons, as Dave suggests, they get a bit bent/weak..need a slight bend to sit square.
Similar Threads
Help with '68 Wood Steering Wheel Horn Cap Installation on a Tilt column ggkeller Interiors 2 Jun 29th, 05 05:32 PM
'69 Horn Contact/Shroud w/Tilt Column PaceCarNut Electrical & Wiring 6 Jan 8th, 05 12:37 PM
Horn won't sound! chassisboy Electrical & Wiring 2 Feb 7th, 04 12:18 PM
Horn Relay wiring? kknapp433 Electrical & Wiring 4 Feb 6th, 02 11:36 AM
Horn relay problems 69 Blk69 Electrical & Wiring 4 Dec 2nd, 01 04:10 PM
