big block motor mounts?? - Team Camaro Tech
Old May 9th, 06, 08:11 PM
blainedoe blainedoe is offline
Blaine
Question big block motor mounts??
Hello everyone I'm in the need of some big block motor mounts for a 67 396. I've been doing some reading and it seems some fit and some don't?? Any advise on where to get them and about how much they should be? I've seen some ridiculous prices. Also heard about some that won''t let your engine raise up if they go bad. Think these came out in 69, but if ther'e thicker i have no room to spare between the hood and air cleaner.
Don't forget to post your results
it's good for the thread
My 67 RS/SS/396
http://i58.photobucket.com/albums/g2...e/100_0461.jpg
http://i58.photobucket.com/albums/g2...e/100_1028.jpg
Old May 10th, 06, 01:15 AM
bb489 bb489 is offline
Tech Team
Default Re: big block motor mounts??
I got mine from Ricks First Generation. Mine is a 68 though. They cost around $18 for both.
Old May 10th, 06, 04:27 AM
fiveforty fiveforty is offline
Do you have the big block frame mounts? They position the motor lower in the frame.
Old May 10th, 06, 04:42 AM
DougP's Avatar
DougP DougP is offline
Doug
agree with fiveforty -- big block frame mounts are shorter than the ones used for a small block, so you need to check that you have the correct frame mount and motor mount --- I had to change the big block frame mounts on another Camaro I built in order to drop in a 350 motor
==Doug
Former 69 Camaro owner
Former 70 Pro Street Nova owner
Former 2nd 69 Camaro owner (pics of resto project)
Old May 10th, 06, 05:30 AM
pdq67 pdq67 is offline
Banned
Smile Re: big block motor mounts??
Nope, taller and tilted.
Please go over to David Pozzi's great site and check out his pic's of what you need.
I bought NOS BB frame mounts years ago and poly "rubber" engine mounts at all three locations and I am so close with a Holley 3310-2 and a Strip Dom that I am running a 14" drop bottomed breather and a 2" filter along with a 7/16" wooden spacer ring on it's bottom to keep air flow OK.
Not the best but like said, too tight otherwise for my just SS hood.
pdq67
Old May 11th, 06, 11:50 AM
shooterpcb shooterpcb is offline
what is David Pozzi's site for the mounts? LINK ?? Thanks
"There are two ways to do this... My way and the Wrong way." - Dale Earnhardt '99
Neil
http://www.chevymania.com/partsid
http://www.mortec.com
Old May 11th, 06, 08:41 PM
Banned
Sorry, I think David still has it in his sig??
David is the Brakes and Susp. Mod here so please check it out.
http://www.pozziracing.com/
pdq67
Similar Threads
Small Block or Big Block PDW HOTRODS Performance 25 Dec 19th, 05 06:21 PM
the last 1969 big block built? Z11/396 Bench Racing 5 Dec 12th, 05 07:08 PM
i got me a factory big block Monte..sorta novaderrik Bench Racing 0 Aug 10th, 05 07:14 PM
Any chance a 650 CFM Holley spreadbore will feed my big block?? Eric Kammerer Performance 9 Aug 5th, 05 07:45 PM
Big Block under SS hood sscoup Camaro Tech 1 May 2nd, 05 08:08 AM
