Fourth Generation 1993-2002
Old May 9th, 06, 10:36 PM
Rokbrigade Rokbrigade is offline
Tech Team
Unhappy My '95 Camaro Z-28 just stopped running.
I was at a stop light. When the light turned green I went and about a minute later, my car just dies and I coasted to a stop. After about 15 minutes, I tried to start it again. It cranked over but it took awhile for the engine finally turn over and then I drove it until it died again just down the street from my house. When I cranked it over again it started to cough but then it finally turned over again in which I made it home. I know it sounds like a fuel pump but, I had a new one installed about 3 months ago and I am getting fuel. My guess is that my distributor is bad because I noticed that it was leaking some coolant at the water pump just above the distributor connection and that there was some moisture present. What do you guys think? Could something else be wrong as well?
Old May 9th, 06, 11:36 PM
RicocheT25 RicocheT25 is offline
Tech Team
Default Re: My '95 Camaro Z-28 just stopped running.
Id check all of your electrical connections also, I had a ground come loose near my main power block (the red one near the battery) come loose from a broken bolt that caused the car to act funny, didn't die on me but tried to.
Other than that it maybe the optical part of the distributor going bad. Its a common thing to go bad on the Lt-1's so it would be the obvious place to look.
I noticed a lot of people post on here about 4th gens and don't really get any answers considering this is mostly a 1st gen site. If you want a lot more info check out www.camaroz28.com for 4th gen stuff. You'll probably get a lot more answers.
Similar Threads
69 camaros on television and movies jsg1010z Bench Racing 30 Dec 3rd, 07 02:05 PM
New 69 CAMARO bodies coporic Bench Racing 16 Feb 25th, 07 09:08 AM
95 Camaro 3.4L V6 Running Rough Camaro Rookie Troubleshooting 3 May 2nd, 06 08:39 PM
A big thanks to team camaro!!! 68 VT Bench Racing 13 Feb 28th, 06 05:41 AM
2004 SuperCar Reunion Labor Day weekend HawaiianCamaro Team Camaro Cruiz-Ins 1 Aug 25th, 04 09:51 PM
