Third Generation 1982-1992
Old May 13th, 06, 11:26 PM
berlinettaboyz berlinettaboyz is offline
jason
Default 3rd gen door nightmare's help
Bought new 83 camaro and I went to replace the pin's and found out the previous owner stuck a bolt in for a pin lol...i need to know what my best
solution would be...A...get new door's or B...replace hinge's. And also need to know how to replace them and if i need to weld or drill or both.
need help please brother's and thanx ...jason
Old May 14th, 06, 11:24 AM
Camaro Dave Camaro Dave is offline
Default Re: 3rd gen door nightmare's help
You shouldn't have to replace the doors.......you can replace or repair the existing hinge. Classic Industries sells new door hinges (upper and lower).
67 RS Camaro 327/ 350 Holley 650cfm > Edelbrock Performer Intake > Pertronix Ignition > Accel Super Stock Coil and Wires > Hedman Hedders > Hotchkis Performance Springs > 15" Rallys all around
Camaro buds until the end!!!
Old May 14th, 06, 03:58 PM
jason
but are they welded on? and will I have to drill? thanx
Old May 14th, 06, 08:11 PM
Jonesy Jonesy is offline
Mike
Yep they are welded. Sounds like you may have to deal with someone who can weld and knows bodywork.
Team Camaro Gold Member #14
1967 Camaro RS/z28 - one of 602 made - SOLD
1969 Camaro RS/SS L48 4 speed
1974 Camaro LT-Z/28 4 speed 33K orig
1984 Camaro z/28 LG4 auto
1971 ElCamino SS454 -Tremec 5 spd
Old May 14th, 06, 10:43 PM
jason
sweet thanx....i guess someone was pulling my leg and told me they are glued on.. (special kryptonite glue)LOL. I knew he was on glue!!!!
Old Oct 11th, 06, 11:19 PM
bobs86iroc bobs86iroc is offline
Tech Team
they are welded but you can buy a bolt on kit you just need to drill the holes just spend some time and get them to fit right with correct gaps and also you can drill out the holes in your hinges and there is a kit with over sized bushings to go in the new holes i would recomend the latter unless you are a body man and good luck
Old Oct 16th, 06, 09:12 PM
kniner kniner is offline
Wayne
Where would you find the oversized bushing. I need to replace mine on my 92. I just can't see spending almost $500 on new hinges when a friend just bought Lambo hinges for alittle more.
http://www.cardomain.com/ride/2483817
Wayne from NC.
Old Mar 26th, 07, 01:27 AM
scooterist50 scooterist50 is offline
alex j
Red face Re: 3rd gen door nightmare's help
lambo hinges-dude would they work with such heavy azz doors?ive gota 89 rs i would like to have lambo doors on it. . . . . . .
Old Mar 27th, 07, 04:03 PM
kustomwerker kustomwerker is offline
mike
welding the holes closed is an easy thing to do...just trace the original holes first, so you know where to redrill...i`ve done it a ton of times...on the other hand, i have alot of welding and fab experience...thats the way i`d go though...
sometimes you`re the windshield and sometimes you`re the bug...
Old Mar 27th, 07, 07:59 PM
Wayne
yes the lambo dorrs will work since they also include heavy duty struts. I've seen one at a show that all you had to do is use you finger. anyway haven't done it yet. man this is an old thread.
Wayne from NC.
Old Mar 31st, 07, 06:51 PM
69-er 69-er is offline
Larry
Here's an article on replacing the hinge pins.
Larry
http://www.chevyhiperformance.com/techarticles/0603ch_1982_1992_chevy_camaro/index.html
Old Apr 1st, 07, 03:36 PM
Wayne
Thanks Larry for that website. I thought it could be done with out all that welding and drilling. Now maybe I'll do mine instead of the Lambo system.
Wayne from NC.
Old Apr 2nd, 07, 11:09 AM
alex j
Exclamation Re: 3rd gen door nightmare's help
ive got a n 89 rs and it needs the bottom pin and bushings on drivers side. is there a way to JUST replace that pin without pulling all that bs and hinges off? my door is fine but i know a new pin and bushings would make it perfect tho. . . . .
Old Apr 21st, 07, 01:26 AM
RONUSMCMMA RONUSMCMMA is offline
Ron
"Top Down Solutions" is the only place to go for this problem .Look for F-Body hinge repair kits . They come in two different version's and specialize in this area . Ask for Lon
1989 RS Camaro ,TBI, 5.0 ,700R4, W/Basic Bolt-on`s
Similar Threads
why is it so expensive to restore?? RUSTY69 Bench Racing 54 May 1st, 07 12:04 PM
Thought someone might find it usefel, others dishearting!! Parts list of my project! boilermaker Camaro Tech 20 Apr 7th, 06 10:14 AM
thinking about switching from 1st gen to 3rd gen tmannet Bench Racing 37 Nov 14th, 05 09:26 PM
3rd gen steering box upgrade, what about pump? ck 2 Brakes, Suspension & Steering 8 Jul 13th, 05 01:32 PM
Has anyone used a 3rd gen console in a 1st gen? MStennes Interiors 1 Apr 17th, 05 06:25 PM
