Cowl Induction Problems - Team Camaro Tech
Troubleshooting Diagnosing problems done here.
Old May 16th, 06, 08:46 PM
jimi302z28s jimi302z28s is offline
Tech Team
Unhappy Cowl Induction Problems
Hey Guys, Can anybody help me???? Installed new cowl induction on my 69 Z Iam not getting the solenoid to work? The relay clicks when you push on the detent switch, but the solenoid does not open the flapper? I tested the solenoid with 12 volts direct to it, and it works and opens fine, What am I over looking??? Thanks if you can help!!!!!!!!!! Jimi302z28s
Old May 17th, 06, 03:14 AM
nashcar nashcar is offline
Steve
Default Re: Cowl Induction Problems
I had the same problem. Mine had a bad relay. It's the one that's fastened to the firewall. The flapper would open when it was jumpered with hot wire. Replaced the relay and works fine now. Also make sure you're getting a good connection at the plug-in on the hood. Good luck!
1969 Z28
http://www.byjanmarie.com/camaro/Z28.html
1969 Firebird 400 one owner.!
http://www.byjanmarie.com/firebird/69.html
My new project for 2010 DONE/ Sold.
http://www.byjanmarie.com/camaro/69camaro.html
2002 Camaro SS LE/SLP
Old May 17th, 06, 04:14 AM
m22mike m22mike is offline
Mike
Wink Re: Cowl Induction Problems
Make sure the solenoid is grounded good, Did you paint the solenoid or the bracket??? If you look at a original bracket ther is a small dimple that is supposed to bit into the solenoid body and supply the ground.
Take a jumper from the solenoid to a ground strap and try that first. I have seen this several times.
Old May 17th, 06, 05:20 PM
Tech Team
Thumbs up Re: Cowl Induction Problems
Hey I didnot have it grounded!!! problem solved! Thanks for the help!! M22mike! Jimi
Similar Threads
What is Cowl Induction? Alfonso Perez Performance 31 Nov 29th, 10 09:50 AM
Cowl induction base 40Coupe Performance 1 Dec 17th, 05 01:05 PM
4 inch cowl induction pics wanted CanCamaro Body Shop 7 Dec 16th, 05 10:30 PM
cowl induction vs. ram air timemachiness Performance 9 Sep 6th, 01 01:35 PM
Cowl induction GregSS396 Tech 2000 4 May 5th, 01 05:53 AM
