1996 camaro, will not start? - Team Camaro Tech
Thread Tools Display Modes
Old May 26th, 06, 06:11 PM
Gr33n Gr33n is offline
Pat
Default 1996 camaro, will not start?
My son's 1996 camaro will not start when he puts the key in and he gets a security alarm light on the dash and it will not turn over. Does any body know what could be wrong? Thank's Pat
67 rs convertible. 327, 6-pak, 4-speed, 12 bolt
1934 ford 3 window coupe 396, 6-pak, 700-r4.
I love a good burnout.
Pat
Old May 26th, 06, 06:22 PM
Mark C Mark C is offline
Mark
Default Re: 1996 camaro, will not start?
VATS. The built in security system can't (or isn't) reading the resistor in the ignition switch and won't allow the starter to engage, or the injectors to fire. Try cleaning the resistor (black pellet on the shaft of the key) with some WD 40 or something similar. Or try another key. If neither thing works then the wires from the ignition switch to the VATs unit may have broken off. That will rewuire a new ignition switch, or you will have to bypass the VATs connection to the ignition switch. Do a search on VATS and you will find the info you need.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My Engine Compartment
Old May 27th, 06, 12:54 AM
undee72Z undee72Z is offline
Your car has the VATS security system. The cars computer reads the resistance value on the IGN key, with the correct resistance computer allows the car to start, with a incorrect resistance, it will not crank and the security light will come on. Your problem is either the key, the IGN lock or both. Dirt on the key or the contacts inside the lock change the resistance value causing your problem. You can try to clean the pellet on the key or have a new key made, and spray contact cleaner in the lock, or replace the lock. You can also bypass the VATS security system, go here
http://www.12vp.com/info_resistors.htm
Greg U
My 72 Z
Undees 70 SS, street driven drag car
Old May 28th, 06, 12:45 PM
Pat
Thank's for the help, we cleaned the ING and key with WD-40. She's working! Thank's Pat
Pat
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: 1996 camaro, will not start?
Location
Location
First Name
Human Verification
Similar Threads
2 1969 ZL1 Camaro Prototypes 68Baldwin Copo & Dealer 57 May 11th, 09 06:43 PM
1973 Camaro Won't Start, No Spark.... 73CamaroSC Engine 11 Jun 9th, 06 08:34 AM
'91 Camaro RS 6 Cylinder-Cranks But Won't Start gdubya Troubleshooting 1 Feb 4th, 06 04:19 PM
1989 camaro rs 2.8 ruff after start up smeals rich in gas Eugene Troubleshooting 2 May 2nd, 05 06:29 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 08:37 AM
