| Team Camaro Tech Current Topic: 4th gen fan help | ||
| Fourth Generation 1993-2002 |
I have a 94 camaro and the fan in the radiator is not turning on and the engine overheats. I have to run the heat on high to keep the temp regulated. This sucks when its 90 degrees out. Ive checked the wiring to the fan and it seems fine, i put direct power from the battery to it and the fan turns on, and i checked the coolant. Two relays are missing, coolant fan #2 and #3. When i bought the car i didnt have this problem, till about a month after buying it. Those two relays werent there when i bought it and i didnt have this problem. What else may be causing the fan to not be working?
Any suggestions? Last edited by Camaro1588; May 29th, 06 at 08:55 PM. |
Replace the relays first. The outside temperature could be the reason you never had a problem until now. Camaros and vettes are great at staying cool on the road but pull no air hardly at a stop especiall y with no fans. Replace the relays first and then I will be able to help. By the way what engine is in your ride so I can better help you
its a 3.4L V6... i also checked the relays today and they are all working fine. could it possibly be a faulty thermostat or sensor??
If in fact the fan relay(s) are working properly and there are no blown fuses, my next guess would be the temp. sensor on the engine.
ok so after working on the car for a few days this is what i found...
-the sensor had been replaced by the previous owner, and the sensor is new and working -one of the ground "prongs" in the fans relay has shorted out i put a wire from another ground to the relay to turn the fan on so it doesnt ruin the engine and cause more severe problems... so i think its a ground wire issue somewhere between the relay box and the fan motor... if you have any ideas on what to look for to find the problem, any suggestions would be helpful. Thanks. Last edited by Camaro1588; Jun 5th, 06 at 10:45 PM. |
Similar Threads
| why is it so expensive to restore?? | RUSTY69 | Bench Racing | 54 | May 1st, 07 12:04 PM |
| 4th Gen Shifter | MR5231 | Fourth Generation | 2 | May 7th, 06 09:28 PM |
| Thought someone might find it usefel, others dishearting!! Parts list of my project! | boilermaker | Camaro Tech | 20 | Apr 7th, 06 10:14 AM |
| Tips for putting 4th gen bucket seats into a '68? | Chevy-SS | Interiors | 9 | Nov 22nd, 05 11:55 AM |
| 4th gen in 2nd gen? | Prelude00782 | Interiors | 4 | Jul 13th, 05 04:03 PM |
